electric problems
Old Mar 29, 2006 | 01:38 AM
ammob16's Avatar
IYAAYAS
Default electric problems
I'm wondering if anyone else has problems similar to mine. When it gets cold outside and I turn my lights on the only ones that come on are my front cornermarkers and that is it. No interior lighting or tailight, highbeams work when they are switched on but other than that no headlights. Of course they headlights and cluster lights will come on eventually, sometimes I can go forever without any cluster lights but they eventually kick on.
Old Mar 29, 2006 | 04:45 AM
yellowrexsi's Avatar
Default Re: electric problems (ammob16)
I have heard of similar problems when its cold. I personally have never had that problem, thank god.
Old Mar 29, 2006 | 05:45 AM
ammob16's Avatar
IYAAYAS
Default Re: electric problems (yellowrexsi)
it sucks *****!!!!!!
Old Mar 29, 2006 | 06:15 AM
noodlerooney's Avatar
Had similar problem, ended up being my ignition switch, was very dirty, cleaned up contacts, problem solved.
Modified by noodlerooney at 4:54 PM 3/30/2006
Old Mar 30, 2006 | 04:38 AM
ammob16's Avatar
IYAAYAS
Default Re: electric problems (noodlerooney)
I just did a search to no avail, but how do you clean the ignition switch?
Old Mar 30, 2006 | 03:44 PM
Check out redpepperracing.com and crx.honda-perf.org, lots of info about this there. They will explain it in great detail, better than I ever could. Basically, you remove the ignition switch, disassemble, then clean the dirty ignition contacts.
Etorres325
Nov 2, 2009 06:29 PM
Etorres325
Oct 31, 2009 06:06 AM
Etorres325
Lighting
Oct 30, 2009 11:39 PM
L-Acura-S
Aug 15, 2008 08:18 PM
sj993
Dec 20, 2004 06:30 PM
