Quick Exhaust Question.
this may confuse you a bit, hopefully it will help in some way.
the b pipe will fit depending on your header/cat setup and the tip of the muffler will be longer.
so it all depends on what your trying to do.. for example... i have a 92 hatch with the oem manifold, type r cat, with type r b pipe with an eg/ek spoon n1 muffler. everything matches up fine...
the itr and civic b pipes are all the same lengths. just the diameter is different.
