uneven tire wear
Old Mar 28, 2006 | 09:23 PM
doodooheadfart's Avatar
Default uneven tire wear
i bought some rota slipstreams with 205/50-15 dunlop direzza's around christams time '05. i ordered them online and they said that they were ready to roll when they arrived at my door step. so i mounted them and have been driving them ever since. except my front tires are wearing REALLY REALLY quickly compared to the rear. any ideas of what this could be?
they seem to wear away more the further you move out (from the inside of the tire)
Old Mar 28, 2006 | 10:16 PM
sirg-vtec's Avatar
Default Re: uneven tire wear (doodooheadfart)
Did you get an alignment? Rotation?
Old Mar 28, 2006 | 11:29 PM
EK k kay's Avatar
Default Re: uneven tire wear (sirg-vtec)
Yeah get an alignment and set the toe to zero. Also make sure you have your tires properly inflated.
Old Mar 29, 2006 | 06:29 AM
Sequoyah's Avatar
Default Re: uneven tire wear (makemoney)
Good suggestions above, but if you have done all of that...and don't have hub-centric rings you need to get some.
Old Mar 29, 2006 | 07:06 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: uneven tire wear (Sequoyah)
All of the above are good suggestions.
When the car is up on the lift, make sure your suspension is okay. Things like worn bushings can cause uneven tire wear too.
Old Mar 30, 2006 | 04:53 AM
yeah i have the hub-centric caps, they have always been there. but i didn't get an allignment or rotation. can someone thoughly explain these to me. i basicly know what they mean but im not too sure... (noob)
Old Mar 30, 2006 | 06:18 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (doodooheadfart)
Rotation is the process of moving your wheels and tires around to different corners of the car, normally done periodically to even out the tire wear. On FWD cars, the front tires wear faster. Some tires can be rotated from one side of the car to the other, while others can't. Look in your owner's manual for the recommended rotation pattern, and check your tires to see if the sidewall says "THIS SIDE FACES OUTWARDS" (which can be rotated from one side to the other) or "DIRECTION OF ROTATION" (with an arrow, which means they can't be rotated without dismounting them from the rim). Tires do not come off the rims during a rotation. Rotation can be done with a jack and a lug wrench (just like putting the spare tire on your car), using an extra wheel/tire to replace the one you take off as you work your way around the car.
You can find a good description of the wheel alignment process on this website.
Old Mar 30, 2006 | 04:04 PM
awesome!
thanks alot
i think i found my problem
i need an alignment
BAD!
Old Apr 1, 2006 | 03:59 PM
i went and got an alignment today...
turns out my left tie rods broken...
Old Apr 1, 2006 | 04:01 PM
nsxtasy's Avatar
H-T Order of Merit
That'll do it... (and that's why I suggested checking the suspension)
Old Apr 3, 2006 | 12:41 PM
how hard is it to replace it yourself?
they want to charge me $180 for it then labor. but atleast i get a free alighnment for the next 6 months!
Old Apr 3, 2006 | 06:27 PM
.Ry's Avatar
.Ry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to replace it yourself?
they want to charge me $180 for it then labor. but atleast i get a free alighnment for the next 6 months! </TD></TR></TABLE>Thats nuts!! At sears they normally go $40 for outer tie rod, and $62 for inner, just for labor. The part is normally under $55.
Old Apr 4, 2006 | 08:39 PM
should i got to sears or install it myself...
Old Apr 11, 2006 | 08:06 PM
91blueciv's Avatar
install your self
Old Apr 11, 2006 | 08:36 PM
help me find a write up or something
ive been searching and i can't find any
Old Apr 12, 2006 | 06:28 AM
nsxtasy's Avatar
H-T Order of Merit
If you want to work on your own car, you really need to have a service manual. You can buy one here.
Old Apr 13, 2006 | 04:37 AM
awesome
thanks alot bro
Old May 29, 2006 | 08:51 AM
alright it's been about a month and a half and i replaced the tie rod(it was broken) but i keep hearing some noise from the front passenger side when i go over a bump, spounds like something is popping in and out of place
inner tie rod?
Old May 31, 2006 | 05:27 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart &raquo;</TD></TR><TR><TD CLASS="quote">alright it's been about a month and a half and i replaced the tie rod(it was broken) but i keep hearing some noise from the front passenger side when i go over a bump, spounds like something is popping in and out of place
inner tie rod?</TD></TR></TABLE>
I don't know. You might want to try asking in the Civic forum...
Old Jun 8, 2006 | 08:59 PM
turns out the upper control arm was loose
mickey513
Jul 2, 2004 08:26 PM
SOHCMAN
Jan 15, 2004 08:11 AM
preluder
Apr 21, 2003 09:19 AM
rickbear
Honda S2000
Jun 24, 2002 05:25 AM
onyx00
Jun 9, 2002 07:24 PM
