Suspension & Brakes Theory, alignment, spring rates....
-- Post your spring rates ! --
Old Mar 28, 2006 | 07:51 PM
Rob.'s Avatar
Default -- Post your spring rates ! --
Car: 1990 Civic Si
Suspension setup : GC/Koni yellows
Spring rates : 550lbs front 650lbs rear.
Comments : Koni shocks adjusted 1 full turn from stiffest setting.
Love this suspension !!!
Old Mar 28, 2006 | 09:34 PM
Tornadom's Avatar
Default Re: -- Post your spring rates ! -- (Rob.)
Car: 1994 Acura Integra GS-R Sedan
Suspension Setup: Koni Sports (yellows) with Ground Control Coil-overs
Spring Rates: 380lb/in Front & 430lb/in Rear
Comments: I also have a 22mm rear sway bar and subframe brace kit (Suspension Technique Speedtech). I recently had Tein RS coil-overs, and switched to the GC/Koni setup for a better daily driving setup. So far I don't miss my Teins.
Modified by Tornadom at 9:42 PM 4/2/2006
Old Mar 28, 2006 | 11:23 PM
EK k kay's Avatar
Default Re: -- Post your spring rates ! -- (Tornadom)
Car: 1999 Civic Hatchback
Suspension setup : Koni Yellows / H&R Sports
Spring rates : 330f / 280r or 250r? (not sure about rears)
Comments : Shocks 3/4 turn from full soft. Fronts set on stock perch setting, rears set on bottom perch setting. Not too stiff, not too soft street ride.
Old Mar 29, 2006 | 07:27 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Car: 1999 Civic CX
Suspension setup : KSport
Spring rates : 11k f/ 9k r
Comments : Don't need rear-biased rates since I DD
Old Mar 29, 2006 | 08:15 AM
fwdtamiya's Avatar
Default Re: -- Post your spring rates ! -- (BrokeAssPinoy)
Car: 1993 Civic Sedan
Suspension setup : Omnipower Sport
Spring rates : 12k front/10k rear
Comments : Need better damping
Old Mar 29, 2006 | 10:07 AM
BodyKits NW's Avatar
Default Re: -- Post your spring rates ! -- (fwdtamiya)
Car: 2000 Civic Coupe
Suspension setup : Ksport
Spring rates : 8k front/5k rear
Comments : This is my Daily Driving setup. I have seperate setup I use when I am looking to track the car. But with 17" rims and 40 series tires, my street setup is the best way to go.
Modified by BodyKits NW at 1:57 PM 3/29/2006
Old Mar 29, 2006 | 10:36 AM
CivicFerio's Avatar
Default Re: -- Post your spring rates ! -- (BodyKits NW)
Car: 1999 Civic EX
Suspension setup : Koni threaded suspension kit
Spring rates : 400lbs front 300lbs rear ERS
Comments : Koni needs more low speed damping. Spring rates for DD comfort. Very good suspension overall.
Old Mar 29, 2006 | 11:40 AM
oOoEG6oOo's Avatar
Default Re: -- Post your spring rates ! -- (CivicFerio)
Car: 92 civic cx
Spring rates : 11k front/7k rear
Comments : i feel everything
Old Mar 29, 2006 | 12:06 PM
alwaysoverkill's Avatar
Car: 1999 Acura 1.6EL
Suspension set-up: Buddy Club Racing-Specs
Spring rates: 10K/7K
Comments: Pretty stiff sometimes here in Toronto and pothole dodging is a must, but wicked handling with a 23mm rear sway bar. Just alittle stiff.
Old Mar 29, 2006 | 07:41 PM
Default Re: -- Post your spring rates ! -- (oOoEG6oOo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oOoEG6oOo &raquo;</TD></TR><TR><TD CLASS="quote">Car: 92 civic cx
Comments : i feel everything</TD></TR></TABLE>
what size tires are you on?
Old Mar 29, 2006 | 09:58 PM
Fobtions's Avatar
B+g coilover shocks
500lbs all around
Old Mar 29, 2006 | 10:04 PM
frozenb's Avatar
car: 97 ITR
suspension: spoon adj damper
spring rate : 16k F/ 18k R
GOOD ride. you can imagine how GOOD is the ride..........................................on track.....and you body won't stop jumping around when driving on street..j/k
it's not bad on street, it's really a good damper
Old Mar 30, 2006 | 10:34 AM
lil'ek's Avatar
Default Re: (frozenb)
car - '99 civic coupe
suspension - skunk 2 adj. coils/tokico illuminas
spring rates - f/r 8kg/6kg
comments - ST bar on the back, i think the diameter is 19mm, not sure. springs are a little too stiff for DD, but it's livable.
Old Mar 30, 2006 | 11:08 AM
dFreezy's Avatar
Default Re: (lil'ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lil’ek &raquo;</TD></TR><TR><TD CLASS="quote">springs are a little too stiff for DD, but it's livable.</TD></TR></TABLE>8k/6k is too stiff???!
Old Mar 30, 2006 | 12:10 PM
lil'ek's Avatar
Default Re: (dFreezy)
yeah, too stiff.. you should see the bombed out roads i have to drive on
RuCkUs24
Suspension & Brakes
16
Mar 6, 2011 06:45 AM
HighRevn
Jun 14, 2009 05:23 PM
kisceneret
Suspension & Brakes
Jan 29, 2008 07:47 PM
BrownGSR
Feb 3, 2004 10:36 AM
HondaJon
Nov 28, 2001 01:43 PM
