all motor ls dyno
Old Mar 28, 2006 | 07:07 PM
JDMTurboEG6's Avatar
Default all motor ls dyno
i dynoed my all motor ls yesterday. i just wanted to get some base #'s before i boost.
jdm b18b stock block
j's intake
s2000 tb
blox manifold
mugen header
spoon exhaust
type r flywheel
i put down 137hp and 110 ftlb torque. air fuel was around 10.4 to about 11.8. anyone else get about the same #'s from a pretty stock ls?
Old Mar 28, 2006 | 09:20 PM
JDM MonopolyMan's Avatar
no vtax?
Old Mar 28, 2006 | 09:34 PM
Default Re: all motor ls dyno (JDMTurboEG6)
nope no vtec just wanted some baseline #'s before boost.
Old Mar 28, 2006 | 09:41 PM
saver's Avatar
i thought it would of been more TQ then that. but nice set up. you first went with the intake side then the exhuast. nice. now you need a computer. one other thing. i never heard of putting a s2000 TB on a Bmotor
Old Mar 28, 2006 | 11:37 PM
shythappenz's Avatar
i remember around last year when i had my stock b18a1 with just a couple of bolt on's i had made 134hp and 123trq. i had a b&m fpr, stock intake,dc 421 ceramic header, stock piping, gutted cat, with an apexn1 style can.
Old Mar 28, 2006 | 11:41 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote"> air fuel was around 10.4 to about 11.8.</TD></TR></TABLE>
That' pretty rich. 13.0:1 would have netted you better numbers.
Old Mar 29, 2006 | 08:54 AM
Default Re: all motor ls dyno (saver)
yea thats what i thought. my freind in his b16 put down more torque then i did. i think maybe my flywheel is why i lost torque but im not sure.
Old Mar 29, 2006 | 08:56 AM
ill get a post of the graph. its pretty smooth. i only took it up to 7200 and it doesnt drop off i think maybe if i went a little higher in the revs id net more power. oh yeah ive got video of it if anyone wants to see it.
Old Mar 29, 2006 | 02:52 PM
Darkane's Avatar
the torque is low because its running rich.. Well most likely timing might be retarded too. Check that. But good power from an LS.
Old Mar 29, 2006 | 02:54 PM
97L-esVeeTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">yea thats what i thought. my freind in his b16 put down more torque then i did. i think maybe my flywheel is why i lost torque but im not sure.</TD></TR></TABLE>
Pig rich...lean it out a bit...I don't do turbo, but that seems rich even if you were boosted...and no your flywheel has nothing to do with your torque numbers.
Old Mar 29, 2006 | 03:42 PM
Default Re: all motor ls dyno (97L-esVeeTeg)
any ideas why my torque is so low? its a good motor, compressions even all the way across at about 190 each cylinder.
Old Mar 29, 2006 | 03:45 PM
B_CRUZ!'s Avatar
Default Re: all motor ls dyno (Darkane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">any ideas why my torque is so low? its a good motor, compressions even all the way across at about 190 each cylinder. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane &raquo;</TD></TR><TR><TD CLASS="quote">the torque is low because its running rich.. Well most likely timing might be retarded too. Check that. But good power from an LS.</TD></TR></TABLE>
Old Mar 29, 2006 | 05:36 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i dynoed my all motor ls yesterday. i just wanted to get some base #'s before i boost.
j's intake
s2000 tb
blox manifold
mugen header
spoon exhaust
type r flywheel
i put down 137hp and 110 ftlb torque. air fuel was around 10.4 to about 11.8. anyone else get about the same #'s from a pretty stock ls?</TD></TR></TABLE>
damn...i thought the torque would be alot higher...but my friends just dynoed his DA with a bone stock gsr swap...he made 140hp...i'm not sure about the torque though numbers though...
Old Mar 29, 2006 | 06:27 PM
yeah timings on. ill try to lean it out maybe adjust fuel pressure.
Old Mar 29, 2006 | 06:52 PM
http://media.putfile.com/all-motor-ls
thats the video ill get the graph up tomorrow
Old Mar 30, 2006 | 10:35 AM
Old Mar 30, 2006 | 11:36 AM
djmota's Avatar
jeez that thing is running rich. some AF tuning and you'll probably see another 5 whp at least especially up top.
Old Mar 30, 2006 | 05:18 PM
JCushing's Avatar
Default Re: all motor ls dyno (djmota)
kind of ironic your dyno says "torque freaks" on it
Old Mar 30, 2006 | 07:01 PM
Default Re: all motor ls dyno (JCushing)
yea it sucks my freinds b16 makes more torque
Old Mar 30, 2006 | 07:08 PM
MaGoodc2's Avatar
you should have took me with you to the dyno testing. but that was a far *** driver
Old Mar 31, 2006 | 06:30 PM
Default Re: all motor ls dyno (MaGoodc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaGoodc2 &raquo;</TD></TR><TR><TD CLASS="quote">you should have took me with you to the dyno testing. but that was a far *** driver</TD></TR></TABLE>
what!!? i did invite you but you were bein lazy!!
Old Apr 1, 2006 | 06:40 AM
MaGoodc2's Avatar
ya... thats true
ohsnapzafingcu
18
May 19, 2009 07:16 PM
89hatcher
11
Jun 20, 2007 03:37 PM
cougar10ag
Apr 3, 2004 07:05 PM
HondaManR
Honda S2000
16
Jun 9, 2003 08:29 AM
