Which Aluminum cam seals?
Old Mar 28, 2006 | 05:16 PM
eluder33's Avatar
Default Which Aluminum cam seals?
I gonna order some of these aluminum cam seals which ones are good quality. They have one with 2 o-rings and one with 3 o-rings. I have an H23 so I'd need two of these, right?
which one?
AC AUTOTECHNIC PRO CAM SEALS
OR
BDL Cam Seal
Old Mar 28, 2006 | 06:57 PM
SteveoBA8's Avatar
Default Re: Which Aluminum cam seals? (eluder33)
Either will do the job, you only need 1(goes on intake cam, tranny side)
Old Mar 29, 2006 | 06:04 AM
NoVALude's Avatar
Default Re: Which Aluminum cam seals? (SteveoBA8)
I went with BDL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Either will do the job, you only need 1(goes on intake cam, tranny side)</TD></TR></TABLE>
^^^^the other side is where your distributor goes, so only one is needed.
Old Mar 29, 2006 | 06:56 AM
mgags7's Avatar
hrm...the BDL is only a 2 o-ring design, when they were STR, im almost sure they were 3....i have an STR in mine, never leaks....
Old Mar 29, 2006 | 07:42 AM
ChrisRicketts's Avatar
Default Re: (mgags7)
i've got an AEBS.....it's got 3 rings as well. any of them will work just fine.
Old Mar 29, 2006 | 08:08 AM
NoVALude's Avatar
Default Re: (ChrisRicketts)
I figured even (1) o-ring on the aluminum seal would be better than the crappy rubber OEM cam seal.
Old Mar 29, 2006 | 09:42 AM
mgags7's Avatar
yeah anything is better than the crap oem one...i say go with a 3 ring if you can find it....
Old Mar 29, 2006 | 10:50 AM
SteveoBA8's Avatar
My str 3 o-ring is holdn strong still, i applied rtv also.
Old Mar 29, 2006 | 12:08 PM
skunked's Avatar
Default Re: (SteveoBA8)
BDL + Hondabond
Old Mar 29, 2006 | 03:11 PM
cruzin89lude's Avatar
i have some 2 ring ebay one and the valve cover gasket if you want them. 25 shipped
Old Mar 29, 2006 | 10:40 PM
i_kick_turtles's Avatar
I had a KMS one. Only 2 rings but it never leaked.
vlc92189
Mar 15, 2007 05:34 AM
djnikko
Feb 24, 2006 09:09 AM
blueintegra90
May 18, 2004 12:47 PM
crazzeboost
Jan 23, 2004 12:06 PM
