Cam Lobe Wear...
Old Mar 28, 2006 | 04:59 PM
Matty.'s Avatar
Default Cam Lobe Wear...
What are the chances that daily driving for over a year with a really stiff valvespring like the JG Pro Series inners/ outers combo, would wear down the lobes of some large lobe cams like JUN III's?
I've read about in troubleshooting guides and know its possible but don't hear about it too often. Just wondering if a valvetrain like the above will eventually cause damage on a DD setup?
Old Mar 29, 2006 | 06:41 AM
Matty.'s Avatar
Default Re: Cam Lobe Wear... (gumtape_deathmatch)
ttt
Old Mar 29, 2006 | 06:44 AM
Dan Ruddock's Avatar
https://honda-tech.com/zerothread?id=1573792
Old Mar 29, 2006 | 07:16 AM
Matty.'s Avatar
Default Re: Cam Lobe Wear... (Dan Ruddock)
I'm not sure I am getting your point. The link you gave me discussed dino vs. synth oils and oil additive packages rather than big cams/ high valvespring rates?
Old Mar 29, 2006 | 07:26 AM
The point is use the advice on the thread and you should not have a problem. Dan
Old Mar 30, 2006 | 11:41 AM
Matty.'s Avatar
Thanks for the advice. Sounds like you know your stuff on motor oils. I'm just trying to educate myself a bit and build smart.
Any idea how Royal Purple 10w-40 compares? (BTW, F*ck the haters, I've used it in my turbo car 6 years ago and had good luck with it ever since.)
Old Mar 30, 2006 | 12:56 PM
Is Royal Purple SL or SM api rated? If SM I would add 4oz. of GM EOS to it with an oil change. Dan
Mikeyto
16
Mar 11, 2012 04:26 PM
bads2k
Jan 16, 2010 04:59 PM
kPRO dz
Aug 10, 2009 08:51 PM
abraunb16
Sep 16, 2002 12:29 PM
