B18C1 Bolt-on choices.
I have a B18C1 and so far I have,
B18C1
GSR tranny
JG 65mm throttle body
JG intake mantifold
JG header
Mugen chipped p28
ITR cams
Skunk2 adjustable cam gears
PasswordJDM Powerchamber Intake
I'm going to have my motor fully built in the summer, I've heard that I'm losing alot of midend power with my current tb/im setup. I'm thinking of going back with the oem gsr tb/im with the itr header, or get ITB with the itr header. Which will produce more power and get me a better 1/4 time?
Thanks in advance!
Modified by vc at 4:00 PM 3/28/2006
B18C1
GSR tranny
JG intake mantifold
JG header
Mugen chipped p28
ITR cams
Thanks in advance!
my friends b18c1 put down 172 whp on dynojet completely stock internals in a 97 gsr, with skunk2 old intake manifold- stock TB, iceman gsr cold air primary tube with pvc 3' to the headlight, 4-1 2.5' jdm copy header, 2 1/4 exhaust with greeddy evo muffler, fpr, uberdata tuned p28 ecu, 14 lbs flywheel, no p/s, that's all, no cam gears , the gsr runs 14.4-96 - 2.1 60 ft time untuned with p73 ecu and sir tranny not lsd. What jg im are you using? the victor-x?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1_POWER »</TD></TR><TR><TD CLASS="quote">my friends b18c1 put down 172 whp on dynojet completely stock internals in a 97 gsr, with skunk2 old intake manifold- stock TB, iceman gsr cold air primary tube with pvc 3' to the headlight, 4-1 2.5' jdm copy header, 2 1/4 exhaust with greeddy evo muffler, fpr, uberdata tuned p28 ecu, 14 lbs flywheel, no p/s, that's all, no cam gears , the gsr runs 14.4-96 - 2.1 60 ft time untuned with p73 ecu and sir tranny not lsd. What jg im are you using? the victor-x? </TD></TR></TABLE>
no p/s a/c here either. the jg I'm using right now is not the victor-x.
just get a complete swamp, it is the best bang for your buck! i had a '99 GSR with a JDM ITR swap that came with lsd, gears, and much more. But make sure the swap is '98 or newer. i tried everything to my B18C1 which included a skunk2 IM, skunk2 exhaust, test pipe, chipped CPU, skunk2 cam gears, intake, and even tried a DC header which i pinched shut do to my car being to low and all this was a waste because as soon as i got that JDM ITR swap in it made everything else seem like a waste...... that will deff give u a better 1/4 mile time! oh and by the way the ITR cams wont do that much in the b18c1 engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Wow.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not133t »</TD></TR><TR><TD CLASS="quote">just get a complete swamp, it is the best bang for your buck! i had a '99 GSR with a JDM ITR swap that came with lsd, gears, and much more. But make sure the swap is '98 or newer. i tried everything to my B18C1 which included a skunk2 IM, skunk2 exhaust, test pipe, chipped CPU, skunk2 cam gears, intake, and even tried a DC header which i pinched shut do to my car being to low and all this was a waste because as soon as i got that JDM ITR swap in it made everything else seem like a waste...... that will deff give u a better 1/4 mile time! oh and by the way the ITR cams wont do that much in the b18c1 engine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not133t »</TD></TR><TR><TD CLASS="quote">just get a complete swamp</TD></TR></TABLE>
lol
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc »</TD></TR><TR><TD CLASS="quote">Which will produce more power and get me a better 1/4 time?
Lose the JG Victor X manifold. Get some good engine management and invest in tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Lose the JG Victor X manifold. Get some good engine management and invest in tuning.</TD></TR></TABLE>
I agree as well.
That manifold is too much for your setup. Something along the lines of an AEBS/Blox/S2 manifold would suit you better.
Also, tuning=deciding factor on how reliable/fast your car will ultimately be.
I agree as well.
dustinbs144
17
Mar 22, 2011 12:22 PM
