<<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>>
Old Mar 28, 2006 | 01:18 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>>
AS the topic states i figured out a very easy way to have an obd1 ecu that has a CROME programmed chip ( or hondata, uberdata ect) for racing and then with the flip of a switch you are back to the OEM stock program...... not rocket science but kool anyways....
You ask why would i want to change from my TUNED program back to the stock and vise versa??
1. most important SMOG CHECKS!!
2. letting friend/girlfriend/family borrow your car
3 leaving your car at an auto repair shop
4 valet parking
5. sandbagging a race
6.....uhhh i dont know
anyways here are some shitty pics (cell phone) of a P72 that i tuned on crome and added the ability to change back to the stock program.... this works out well for this particular customer because his tuned prog has a rev limit of 9500 and of course when he flips the switch it is back to 8000. (he shares the car with his older brother who cant drive for ****)
Old Mar 28, 2006 | 01:21 PM
( o )( o )'s Avatar
Default Re: <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>> (HOOKUPS)
so are you going to post up a how-to? or are you taking orders for this service?
good **** mang.
did i mention
Old Mar 28, 2006 | 01:29 PM
AllMotorMark's Avatar
not to burst your buble this has been done about 3-4 years ago atleast
Old Mar 28, 2006 | 01:33 PM
unknown0001's Avatar
Default Re: <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>> (AllMotorMark)
awesome because I did this too on my ecu. With a flip of the switch your running the stock program or the edited maps
Old Mar 28, 2006 | 01:41 PM
aZnjCC's Avatar
This is perfect for daily drivers / weekend race cars that run different exhaust setups and such. Need completely different tunes
oh wait....or can it only be the stock program and custom, not two customs?
Old Mar 28, 2006 | 01:51 PM
GUILOTINE's Avatar
Kill Gil
very ingenious Chris
Old Mar 28, 2006 | 01:52 PM
Chris22215's Avatar
Default Re: (aZnjCC)
that switch is probably connected to the Jumper J1. So you disconnect the jumper and you're back at the stock program. There are ways that you can use a different chip and have 2-3 different modified programs ready to go
Old Mar 28, 2006 | 02:03 PM
aZnjCC's Avatar
Default Re: (Chris22215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris22215 &raquo;</TD></TR><TR><TD CLASS="quote">that switch is probably connected to the Jumper J1. So you disconnect the jumper and you're back at the stock program. There are ways that you can use a different chip and have 2-3 different modified programs ready to go </TD></TR></TABLE>
you're right...that makes much more sense after I thought about it more.
Old Mar 28, 2006 | 02:09 PM
DYNO-PRO
i wasnt playing GOD or anything i was just bored and tried it and it worked im working with the local electronics store to come up with a was to go from stock program to TUNED program to a different TUNED program..... so for the peeps that have done this before good for you maybe somebody should have shared this info.. anyways i am offering this to my customers.
Old Mar 28, 2006 | 02:48 PM
fastlifemotorsports's Avatar
Good option to give Customers Give us more info!!!!!!!!
Old Mar 28, 2006 | 02:54 PM
EK9-Stealth's Avatar
ill second that... ahaha loving the title... new dsicovery!! all in caps
Old Mar 28, 2006 | 03:56 PM
UNKNOWN_MEMBER's Avatar
Default Re: (EK9-Stealth)
can it be 2 different TUNED maps instead of 1 tuned map and stock?
Old Mar 28, 2006 | 04:04 PM
H25's Avatar
H25
Great find!! But,This has been around on the net for quite some time now. I have gotten jdm ecus with the switch as well, Its pretty common in japan im told.
Old Mar 28, 2006 | 04:11 PM
dax-es's Avatar
Default Re: (UNKNOWN_MEMBER)
If it's like this one below, then you should be able to run two different maps and switch between them with the car running. I don't see why you'd just add a switch to go back to stock, though.
Old Mar 28, 2006 | 04:12 PM
saver's Avatar
Default Re: <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>> (MHRacing-310)
i hope no one repeats the other who says " its been done already" it gives me headachs. i didnt freaking know about this. ppl dont talk about it i guess. well it sounds good. its like have a boost controller.
Old Mar 28, 2006 | 04:39 PM
jetpilot's Avatar
pgmfi.org
on a 512k eprom you can store 2 diferent tuned maps and change between them, On the forum theres info on how to do this, very simple.
moates.net and xenocron.com both sell the kit for $30
Old Mar 28, 2006 | 04:40 PM
DYNO-PRO
Default Re: <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>> (saver)
workiing on switch between two seperat progs... maybe one for race gas and one for pump???hmmm
Old Mar 28, 2006 | 05:10 PM
FaceTuned's Avatar
basically thats a switch cutting off the j1 jumper!
i guess thats cool.
Old Mar 28, 2006 | 05:34 PM
88 rex's Avatar
pgmfi.org is your friend. I'm actually surprised that a pretty popular tuner like you hasn't discovered this long ago. FI guys do this for highway driving to lean it out and get great milage and then flip it back to "race" mode. I think there are other options where you can switch b/w multiple (more than 2) fuel maps.
In any case, I'm glad you're offering it as an option
Old Mar 28, 2006 | 05:51 PM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">... maybe one for race gas and one for pump???hmmm </TD></TR></TABLE>
This chip really sounds like something more for FI guys, nevertheless. a step foward
Old Mar 28, 2006 | 06:07 PM
DYNO-PRO
Default Re: <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>> (91' LS-VTEC)
Well I guess I was a step behind in the whole dual program ecu.... Just never heard anyone mention it on this site..... Somebody pleasee remind me not to share my thoughts anymore ...god I'm an idiot..... F&gt;&gt;kin know it all haters lol
Old Mar 28, 2006 | 06:19 PM
2k.civic.si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
This chip really sounds like something more for FI guys, nevertheless. a step foward </TD></TR></TABLE>
its good for n/a guys to...you can setup one program with drag launch for street and one for the track...or a valet mode for if someone else drives your car
Old Mar 28, 2006 | 09:14 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">Well I guess I was a step behind in the whole dual program ecu.... Just never heard anyone mention it on this site..... Somebody pleasee remind me not to share my thoughts anymore ...god I'm an idiot..... F&gt;&gt;kin know it all haters lol </TD></TR></TABLE>
hahahaha
Old Mar 28, 2006 | 10:42 PM
vivid 02's Avatar
I seen this before too. If not many people know about it, it means that there was a lack of marketing for it. Now this is where you should step in and market this with a switch going up to a hidden spot on the dash or something.
Old Mar 28, 2006 | 10:50 PM
H25's Avatar
H25
No your not an idiot. And nobody is "hating"
Pump gas and race program would be aewsome!!
