VAFC Installation - Tuning
Old Apr 3, 2002 | 01:40 PM
ArchAngel Sabastian's Avatar
New User
Default VAFC Installation - Tuning
Who all has installed a VAFC? is it pretty straightforward? Any site online with an install walk-through, and will i be able to set it at all without a dyno? i wont be able to get to a dyno for about a month and id like to install it and set it up if possible now and then fine tune it later. tia
Old Apr 3, 2002 | 04:20 PM
niedejb's Avatar
Default Re: VAFC Installation - Tuning (Sabastian)
I have.
If you have a service manual its simple but dont use APexi's diagrams. They try to lump all cars into 4-5 configurations.
No. Install and leave everything at 0%. You can move Vtec around but thats about it till the dyno.
Old Apr 3, 2002 | 04:23 PM
New User
Default Re: VAFC Installation - Tuning (niedejb)
i have a haynes manual (somewhere..) and about 4 different VAFC.pdf Install guides from the net....
wouldnt moving vtec around and not correcting fuel a bit be bad?
Old Apr 3, 2002 | 04:29 PM
SOHCArchangel's Avatar
you want to correct for fuel when you lower the vtec, like i said sebastion ill give my old settings from memory
Old Apr 3, 2002 | 04:39 PM
New User
Default Re: VAFC Installation - Tuning (SOHCArchangel)
ok, and thanks
Old Apr 4, 2002 | 06:06 AM
chameleon's Avatar
Default Re: VAFC Installation - Tuning (gt-sport)
i will be installing mines today .. so if anyone got any guides for a h22a ecu then let me know. .makes this easier on my part
Old Apr 4, 2002 | 06:18 AM
Default Re: VAFC Installation - Tuning (chameleon)
it should be in the instructions
Old Apr 4, 2002 | 11:59 AM
FastechAccord's Avatar
I installed one on my 97 Ex and it was pretty straight forward, except i had to use the pinouts for the 97+ prelude because the accord pinouts werent even close. Also, the vafc on an accord is pretty useless, vtec kicks in at 2500 from the factory. The lowest you can set it on a vafc is 3000. Unless your adding fuel for a turbo or something along those lines, the vafc isnt worth a damn on a NA accord.
Old Apr 4, 2002 | 12:05 PM
Accord94DX's Avatar
Default Re: VAFC Installation - Tuning (EvoAccord)
but it looks so COOL!!!!!!!!!!!!!!
Old Apr 4, 2002 | 12:07 PM
dude, im sorry but you are incorrect
yes it switches off the idle lobe at 2500 to go onto the mid lobe, and the hi-cam activation is a 5250 rpm, and its lowest point is 3000 k because that is when the oil pressure is at least 50 psi any lower and the lobes would not switch over.
As it for being useless, hardly, my car would much slower if it wasnt for getting on thew hi-cam at 3500
Old Apr 4, 2002 | 12:09 PM
Accord94DX's Avatar
Useless on a N/A non-vtec accord yes?
Old Apr 4, 2002 | 12:10 PM
Default Re: VAFC Installation - Tuning (Accord94DX)
does an non-vtec accord have vtec?
Old Apr 4, 2002 | 12:11 PM
Accord94DX's Avatar
i dont know. I think so.
Old Apr 4, 2002 | 12:12 PM
it does not have vtec
Old Apr 4, 2002 | 12:14 PM
Accord94DX's Avatar
Misa. A quote for you:
[HondaSalesman] "All hondas have VTEC, its just whether the computer tells it to turn on or not...[/HondaSalesman]
Old Apr 4, 2002 | 12:15 PM
that is total bull ****, so an f22a6/4, d15, b18b, zc, and h23's have vtec right?
Old Apr 4, 2002 | 12:19 PM
Accord94DX's Avatar
that is total bull ****, so an f22a6/4, d15, and h23's have vtec right?
um. that was thrown up for entertainment. i pray to baby jesus' left big toe that you dont think i believe that ****.
Mike P.'s Avatar
25 Year Member
Does the computer tell them to turn VTEC on or off? If yes, then it has VTEC.
Old Apr 4, 2002 | 12:20 PM
dude, the posts and crap i have seen lately i dont know WHAT to beleive anymore
Mike P.'s Avatar
25 Year Member
Default Re: VAFC Installation - Tuning (Mike P.)
My Cutlass has VTEC. It "kicks in" when the secondaries open on the carb.
Old Apr 4, 2002 | 12:23 PM
Accord94DX's Avatar
*Stops praying to baby jesus' left big toe*
Old Apr 4, 2002 | 12:38 PM
H23 Power's Avatar
great link for H22 V-AFC install and tuning...
http://members.aol.com/ryoucold/prelude/apexi/apexi.htm
plus check out the mid range gain in power...crazyness
[Modified by 01GSR, 3:39 PM 4/4/2002]
Old Apr 4, 2002 | 12:42 PM
4doorH22's Avatar
Just what "kicks in" at 2500? It's not the VTEC cam xover, that's for damn sure.
Old Apr 4, 2002 | 12:48 PM
Default Re: VAFC Installation - Tuning (4doorH22)
i know what he is attempting to reffer to ill give you a drive when we are wrenching this weekend
Old Apr 4, 2002 | 03:19 PM
smokin rubber's Avatar
would a vafc or regular afc be worth anything for my f22a1, I know i dont have VtECK, but I might get some
