Can I rre-use the H22a Head studs????
Old Mar 28, 2006 | 12:47 PM
drintegra's Avatar
Default Can I re-use the H22a Head studs????
I am replacing my friends head gasket and other things and was wondering if there is a big issue with reusing the headstuds. I reused them on my d16z6 and on the ls also. Just want some experienced people as this is not a big power build just something to make sure the car runs good.
Old Mar 28, 2006 | 01:07 PM
BB6racer's Avatar
you "can" reuse them, but i wouldn't recommend it. you may have gotten away with it on your other motors, but its just a safety/insurance kind of thing. would you reuse a timing belt when you replace the water pump? same kind of idea.
Old Mar 28, 2006 | 01:24 PM
98TypeSH's Avatar
Default Re: (BB6racer)
Get some ARP bolts and you can reuse those a few times. 70 bucks for OEM or 100 or ARP, his choice.
Old Mar 28, 2006 | 01:34 PM
PocketRockets Racing's Avatar
Default Re: Can I re-use the H22a Head studs???? (drintegra)
yes.......is it smart.....no.....new honda bolts for stock or ..ARP for performance
Old Mar 28, 2006 | 01:50 PM
2lude4u's Avatar
Default Re: Can I re-use the H22a Head studs???? (PocketRockets Racing)
While we're on the subject what do you guys think about reusing main bolts?
The ones the hold the girdle/crank in place. My helms manual didn't say anything about replacing them when reassembling, but would like some peoples opinions.
Old Mar 28, 2006 | 03:51 PM
92hondalude's Avatar
Default Re: Can I re-use the H22a Head studs???? (2lude4u)
what about if you have had new head bolts on a car for 3 miles like me only to find out you have a warped head. can i reuse those?
Old Mar 28, 2006 | 04:10 PM
ilikehonda's Avatar
honda head studs are not supposed to be reused. how do i know? best friend works at honda. you can reuse them but they have a good chance of stripping or breaking...just buy arp head studs!
Old Mar 28, 2006 | 04:15 PM
Default Re: (ilikehonda)
put only three miles on my motor i dont think i would have to get new ones
Old Mar 28, 2006 | 04:53 PM
antballs420's Avatar
Default Re: (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">put only three miles on my motor i dont think i would have to get new ones
</TD></TR></TABLE>why? they were torqued right? then there streched. and need to be replaced. the torque specs allow for streching thats why u cant reuse, cause they wont stretch the same and can strip, or worse yet, snap. if they're arp's then u can reuse them cause there studs and nuts, not bolts.
Old Mar 29, 2006 | 05:04 AM
drintegra's Avatar
The reason why I asked was because I will not dissassemble that motor again. It is just to change the headgastket. My friend is not into building stuff just wants to change the gaskets. I will see about the ARP's which I initially recommended to him but Just wanted some feedback from people who may have done this already. THanks
Old Mar 29, 2006 | 09:35 PM
NXLude's Avatar
I reused mine and have had no problems.....if that helps. If i would have to do it again though, i would probably get new ones. Live and learn
Old Mar 30, 2006 | 12:26 AM
Rosko's Avatar
Default Re: (NXLude)
I've reused mine more times than I can count. I wouldnt worry about it if its just a stock motor.
This year however I'll be using arp's... you can only be lucky for so long lol!!
Old Mar 30, 2006 | 03:56 AM
flyrod's Avatar
Default Re: (Rosko)
We have re-used them several times without problems.
Old Mar 30, 2006 | 06:46 AM
drintegra's Avatar
Default Re: (flyrod)
Thanks for the info, I will just reuse as this is more of a stock motor that is not going to be pushed. Thanks again
mtownsi
Jan 20, 2007 10:20 AM
danthemang3
Nov 14, 2006 08:05 AM
civicmatt
May 5, 2003 08:42 PM
HotWheelz
Feb 6, 2003 10:56 AM
shamoo
Jan 21, 2002 02:05 PM
