Lenso's with 24.5 x 9, will they clear?
Old Mar 28, 2006 | 12:44 PM
ozzyman's Avatar
Default Lenso's with 24.5 x 9, will they clear?
I have a set of 13" Lenso's with 24.5 x 9 slicks. I was wondering if this will clear my suspension on my Integra GSR? I havent mounted the slicks on the rim yet but I dont want to have to put it on then have to take them off again. It looks like the 9" might be too wide. Its going to be raised of course, but I'm not sure if thats going to be enough.
The Lenso's..
Old Mar 28, 2006 | 02:20 PM
Rico's Avatar
They should fit, just make sure that you raise the suspension up high enough. Also make sure that you raise it high enough that when the slicks grow it will clear the fenders....
Old Mar 28, 2006 | 02:39 PM
AlphaMike's Avatar
Default Re: (Rico)
They'll fit, but you might need a 1/4" spacer so the inside of the slick doesn't rub on the spindle.
Old Mar 28, 2006 | 08:55 PM
mrbsponge's Avatar
didnt need a spacer on my EG with gsr brakes but i did have to raise it up a couple inches,
should you need a set of 4x100 spacers i stock them
Old Mar 28, 2006 | 10:47 PM
ozzyman's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">didnt need a spacer on my EG with gsr brakes but i did have to raise it up a couple inches,
should you need a set of 4x100 spacers i stock them</TD></TR></TABLE>
Did you have 24.5x9?
Old Mar 29, 2006 | 06:23 AM
BoostedJeff's Avatar
Default Re: (ozzyman)
i ran a 1/4 inch spacer and mine were fine, i ran those tires, the 24.5/9's
you will be fine.
Old Mar 29, 2006 | 06:30 AM
itr_18's Avatar
even 25x9 will fit fine!
Old Mar 29, 2006 | 06:31 AM
Default Re: (itr_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_18 &raquo;</TD></TR><TR><TD CLASS="quote">even 25x9 will fit fine!</TD></TR></TABLE>
im pretty sure he was worried about width, not height
Old Mar 29, 2006 | 01:56 PM
ozzyman's Avatar
Default Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">i ran a 1/4 inch spacer and mine were fine, i ran those tires, the 24.5/9's
you will be fine.</TD></TR></TABLE>
I dont want to have to run a spacer though.
Old Mar 29, 2006 | 06:11 PM
TeamNextGenChris's Avatar
same here.Lensos,24.5x9
Chris
Old Mar 29, 2006 | 09:13 PM
SPOOLINmatt's Avatar
Default Re: (TeamNextGenChris)
**** i have the same wheels with the same size slicks mickeys and i have to run 1/2 inch spacers!! I have GSR spindle/brakes as far as i know. I know i have to buy brakes for a gsr. haha.
Old Mar 30, 2006 | 06:27 AM
93H22ACX's Avatar
Default Re:
i had those with cx brakes.. i had to run 1/2" spacers. the width of the slicks was rubbing....
Got_boost_97
Mar 11, 2013 07:27 PM
boostd ls
Aug 10, 2008 07:27 AM
Chicago_Boosted_SI
Feb 2, 2008 08:31 AM
Tippyman
Jul 11, 2006 05:48 AM
turtle-eg
Nov 8, 2003 10:39 PM
