B18c or B16B???
I have a Ek right now..And i am not sure which motor to go either a B18c or a B16B??..I would like to know sum of your thoughts of which motor should i get for my ek..i also want to go a motor to either motor i get..So which would also be better to go all motor to..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">just go with b18c more torque helps. Same block different internalls. </TD></TR></TABLE>
Its not the same block
B18c = 1.8 liters
B16b = 1.6 liters
But aside, I would go for B18c, well actaully I did. There is no replacement for displacement! Haha a whole .2 liters of displacement.
Which ever one you can get cheaper, either one will make you smile the first time you feel the almighty VTEC
B18c = 1.8 liters
B16b = 1.6 liters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic »</TD></TR><TR><TD CLASS="quote">
!</TD></TR></TABLE>
!</TD></TR></TABLE>
B18c = 1.8 liters
B16b = 1.6 liters
!</TD></TR></TABLE>
you wonna bet?
different internals but the same block. I would even get a gsr over b16b, torque owns. Besides b16b is 1000 over GSR and prolly like $500 less then ITR. Don't get a b16b unless you can find it for like 3gs.
B18c = 1.8 liters
B16b = 1.6 liters
!</TD></TR></TABLE>you wonna bet?
I think it all depends on you future plans. If your planning to stay all-motor then absolutley get the b18c if you want to got turbo however, the money you save buying a b16 will go a long way toward a turbo kit and in the end the net gain will spank any b18c. If money isnt an problem go with the b18c and then turbo it lol
you wonna bet?
different internals but the same block.</TD></TR></TABLE>
So how come they have differnt displacements if they have the same block?
you wonna bet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackRS-T »</TD></TR><TR><TD CLASS="quote">why pay an extra 1500 for 5hp and 10 less ft/lbs of torque go b18c</TD></TR></TABLE>
I think you guys are confusing the blocks. First of all he is asking b16b no b16a junk. B16a is powerless compared to even a gsr.
We are talking about b16b (ctr) and b18c (gsr or itr). If you don't know what you are talking about please stay out of this.
So how come they have differnt displacements if they have the same block?</TD></TR></TABLE>
ait buddy, same bore, same castings. If you read all the casting on the block (except the b16b one) you will find p72 same as gsr and ITR. Second of all the only difference between b16b(ctr) and b18c (itr) are the pistons, rods, crank, and cams. Everything else is exactly the same. Read up before you start talking ****. Blocks are exactly the same.
B16a block is totaly different then b16b block too.
You wonna keep on arguing or are you finaly going to STFU?
Hey man you need to chill, all I did was respond to a question that I thought I knew but it turned out that I did not know. Then I asked a question to clarify. You consider that talking sh@t?
That is the point of this thread to get some unknown information figured out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_go_civic »</TD></TR><TR><TD CLASS="quote">I recommend the b18c1.</TD></TR></TABLE>
From: On a island w/ only a bridge to leave it, U.S.A
Then its not a JDM
Go with which ever one you think you will need the most, and amount of money you want to spend.. Both good engines
Then its not a JDM
i've been asking myself the same question (b18c or b16b) and i think i'm going to be going for the b16b. tranny comes with a lsd stock, can rev it way higher (with proper head work), and i can probably sell most of the parts i take off. ctr cams, header, intake manifold etc... if it says type r on it, you can find someone to sell it to, lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rniederlando »</TD></TR><TR><TD CLASS="quote">Do any others come with LSD's?</TD></TR></TABLE>
a lot of the jdm engines have optional lsd transmissions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon »</TD></TR><TR><TD CLASS="quote">dude you're 14, you're not gettin either one anytime soon. Sell your lego set and buy a bike.</TD></TR></TABLE>
hahaha. I'm keepin that one in my signature dude!
