Slick choice: 14" or 15" wheels?
Trying to choose my slicks for this year. Minimum suggested rim width is 6.7" (7.7" tread width +/- 1" for acceptable rim size).
14" wheels are lighter, will be cheaper, and end up with a larger sidewall on the slick. But they're usually narrower.
15" wheels are far, far, far more available and usually wider, cost is only slightly higher.
Which should I get? What wheels should I get for the slicks? I can't even find 14s in 7" width, no problem finding that for 15s, but I have no idea about weights. I've never even had rims on my car so I just have no clue.
Price is of course a major factor, no custom wheels here...
I havn't looked at slick choices in a while, but there was a lot more variety of size when you are on a 15" rim. I would see if you could pick up some rotas for cheap in 15x7...IMO
What size backspacers are you running mrbsponge and what was the cost on those? I have LS knuckles and it barely clears the CRX wheels; I think they're the same size brakes...
ImportMotorSpec, ya, that's the way I'm leaning right now
Though there is plenty of choice in 13" as well, that's a pretty common race wheel size!
