sucked up water
Old Mar 28, 2006 | 08:40 AM
woehlk's Avatar
Default sucked up water
i went through a big puddle and got water in my engine big mistake please save the laughter about it and give me ur advice do you think anything else is wrong besides the engine being fucked like ignition, ecu, and so on please give me advice cuz i ordered my new motor and i really want it to fire up when i put it in but dont wanna b disapointed when i get it in thanks
Old Mar 28, 2006 | 08:51 AM
CRX Toad's Avatar
Default Re: sucked up water (woehlk)
Typically if water gets into the intake and enters the engine you are looking at a rebuild as you have hydro locked your motor. The parts you names off such as ECU and so forth would not be remotely effected by the physical water.
Old Mar 28, 2006 | 10:39 AM
K DOHC_19's Avatar
Default Re: sucked up water (CRX Toad)
TRUE CRX TOAD.
Old Mar 28, 2006 | 10:54 AM
xfletcherxx's Avatar
Default Re: sucked up water (K DOHC_19)
Yeah, I'm guessing you sucked up some water into your CAI? Make sure you invest in one of those water bypass valve things.
Your new motor should start up fine, and you shouldn't have any electrical problems, unless you drove into a lake maybe?
Old Mar 28, 2006 | 11:04 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Typically if water gets into the intake and enters the engine you are looking at a rebuild as you have hydro locked your motor. The parts you names off such as ECU and so forth would not be remotely effected by the physical water. </TD></TR></TABLE>
the Truth
I have also worked on the same car twice were he sucked water in the intake. It formed a puddle in the manifold, which we sucked it out with a baster, and a rag. Let the car sit overnight and it crunk right up the next day...both times.
Old Mar 28, 2006 | 12:28 PM
Stoich's Avatar
Default Re: sucked up water (Autoworks)
Just in case you got lucky pull the plugs and crank it then replace the plugs and oil and try and start it up. (A friend of mine lucked out once.)
If not they your in for a rebuild.
Good luck brotha
Old Mar 28, 2006 | 12:56 PM
Khmi's Avatar
Default Re: sucked up water (Stoich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">Just in case you got lucky pull the plugs and crank it then replace the plugs and oil and try and start it up. (A friend of mine lucked out once.)
Good luck brotha</TD></TR></TABLE>
You guys are lucky, my friend drove into a puddle and snapped 2 rods.
Old Mar 28, 2006 | 01:10 PM
rsca_crx's Avatar
Default Re: sucked up water (Khmi)
water is only going to really screw things up if you get enough in there that the piston can't go to the top of the stroke because the chamber is full of water. (water doesn't compress well like air does). that's when you break or bend rods.
a little isn't going to hurt anything, and neither case will affect electrical parts, since they have nothing to do with each other. just like if you spill a bucket of water in the interior and fry the ecu, none of your rods are going to spontaneously bend.
what happened to the first motor?
&lt;---, who has also seen how efficient a straw a cai makes in a flood.
Old Mar 28, 2006 | 01:41 PM
mycrx7's Avatar
Default Re: sucked up water (rsca_crx)
my buddies b16 hydro locked when the dumbass went through a huge puddle forgetting his cai was on, and i mean this things locked, 3 rods r bent bad enough they r touching the cyl walls.
Old Mar 28, 2006 | 04:28 PM
blumpfish's Avatar
pretty safe to say your engine is fucked
Old Mar 28, 2006 | 05:53 PM
EsCo_EsCo's Avatar
That happen to me before about 3 years ago...sunny day then came the rain in a matter of minute pouring then next thing u know i got a hole in my block but then came in the ZC
Old Mar 29, 2006 | 08:37 AM
mzahiri's Avatar
I drove through some water yesterday too. I dont have a CAI on but my car is acting up. It will register lean for a bit, then slow down. If, while going lean, I floor it the RPM's will go down to 1200 and then its fine untill I have to shift agin.
Whats up?
KevinEF7
Feb 14, 2013 01:21 PM
jscrib
Sep 26, 2010 04:42 PM
fitboy
Jan 3, 2006 08:53 PM
GZERO
Oct 23, 2002 12:30 PM
slowaccord
Apr 9, 2002 12:56 AM
