need some help on my block.
i got a b18c block. so does that mean its a jdm gsr block? or usdm block. its not b18c1. and would it be better to have 99 gsr head on that block or 95 gsr head?
Buddy , if it says B18c then its a JDM Type R motor!! you are one lucky SOB1!1!
you have better compression and a small gain in HP instead of the USDM one.
so its not usdm? its has itr piston. but sould i use 99 head or 95 head? with some after market cams? will the cams hit the piston?
