215/60/14 on a del sol rim fitment.
these fit, right? i would rather go with the larger side wall if possible. i dont know if the 215 needs a 6.5 inch rim or not, or it will fit on the 6 inch stock rim. thanks.
You're kidding, right? That size is MUCH too big and the tires will rub on the wheel wells. It will also make your car accelerate slower (like getting taller gears) and will throw off your speedometer and odometer by 6.2 percent.
The proper size tire for 14x6 wheels on a del sol is 185/60-14.
Aha! For the dragstrip, that's a different story.
Look up the specs for the tire make and model you're considering, on the tire manufacturer's website or the site of a tire dealer like the Tire Rack. You should find the range of approved rim widths for each size tire.
techsynthesis
Mar 4, 2008 05:28 PM
ApolloSpeed
11
Aug 24, 2005 03:40 PM
