abs light, wtf?
Theres this stupid light in my speedometer that says ABS wtf is that?!
jk..
Anyways my abs light randomly came on yesterday, so i checked the fluid and it was very low, so i topped it off today and it's still on, so i thought maybe a fuse, so i checked all my fuses and they are all good (The ABS Fuses are the ones that say ALB right?)
Anyways, what else could cause my ABS to come on? what should i check next?
jk..
After you fill up to the appropriate amount of fluid, reset the abs system (do a search), and then check your codes if you have any. All of the information you need is only a search away. The code will tell you what kind of problem you are having.
94 gsr, i just did the test for mines, when the key is on, the abs light stays on until the engine check light goes off then i get four fast flashes followed by four more fast flashes. what does this mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 »</TD></TR><TR><TD CLASS="quote">94 gsr, i just did the test for mines, when the key is on, the abs light stays on until the engine check light goes off then i get four fast flashes followed by four more fast flashes. what does this mean?</TD></TR></TABLE>
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Sounds like a rr wheel sensor.
(94-97) ABS DTCs...
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
before i took my abs fuse out, my car would periodically make the humming noise when i start driving. then after awhile, the abs would sometimes kick in when slowing down normally, when i hit about 5 mph the pedal would jump up and make the clunk sound, as if i was on ice. is it true that all i need to replace is an o-ring to fix the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 »</TD></TR><TR><TD CLASS="quote">4/4 sensor, i'm guessing it's the driver rear sensor cause the line is just hanging there, problem solved.</TD></TR></TABLE>
Good deal, what sucks is when your abs light is on and its not throwing a code.
it started when i dropped my car and lost the screw holding the line in the back, also my front sway bar poped out of the joint due to the drop, thought it was cause of that. i hope it still works, the sh*t drives me nuts.
