will a power steering rack from 90 lx 4door fit a 91 crx si?
i am getting another crx tomarrow and i just want to see what all i can use from my parts cars. the car i am getting is a 91 crx si with front end damage, i dont know if it bent the steering or not, but if it did i was wondering if a power steering rack out of a 90 lx 4 door will work on a 91 crx si just not with the power steering hooked up of course
It will fit onto the car all you have to do is use all the brackets from the power steering car to make it fit onto the non power steering car. Then everthing should bolt right up well the rack that is, but if your gonna make the car power steering you have to run all the lines and that be all. If you need a power steering rack let me know i have a new one in my garage.
MIKE
MIKE
hey thanks, also i might just unbolt the subframe and use it off the 90 because it is only 4 bolts and i might need to use the front suspension off the 4 door as well, will the subframe bolt up to the 91 crx si no problem? if so then that might be the way i go
