dyno results, my b20vtec, twm itbs, vid, pics, graph 4/1
Old Mar 28, 2006 | 05:19 AM
Nick M's Avatar
Default dyno results, my b20vtec, twm itbs, a video too!
Alrighty, finally got to the dyno yesterday afternoon after sorting out some bugs, bad distributor guts, overheating, and a vac leak from hell..
First the setup...
B20B Block
balanced crank w/ Eagle Rods & 12.5:1 CP pistons & ARP hardware
CTR N1 crank pulley
Mugen Oil Pan
B16B Head (stock, no port, nothing)
Skunk 2 Stage 2 Cams, springs and retainers w/ AEM cam gears
TWM 50mm ITB's w/ golden eagle vac rail
Pro-1 4-1 Header w/ 2,5" collector (jdm itr copy) to 2.5" mandrel exhaust w/ universal HKS muffler
USDM ITR tranny
Fidanza 7.5lb flywheel
RC 440cc Injectors
B&M fuel pressure gauge
Walrboro 255lb fuel pump
PLX m300 wideband o2 sensor
AEM EMS
tuned by Jdogg, 210whp and 148ft/lbs on a dynojet
Also, the filters I tested, made zero difference in anything, peak power or area under the curve.
Graph:
209.72whp 147.96ft/lbs
Video:
http://evilmachine.net/DSCF0038.AVI
jdogg
Old Mar 28, 2006 | 05:50 AM
00MRSi's Avatar
Default Re: dyno results, my b20vtec, twm itbs, a video too! (Nick M)
Nice glad you were able to get those bugs worked out. Did you say initially your idle was very high, around 3500rpm?
Old Mar 28, 2006 | 05:52 AM
Nick M's Avatar
Default Re: dyno results, my b20vtec, twm itbs, a video too! (00MRSi)
Yeah it wouldnt go any lower than 3500 or so.
The problem was due to the Hondata gasket that was making a very poor seal.
It idles very smoothly at 1000rpms
Old Mar 28, 2006 | 05:58 AM
98vtec's Avatar
moderator emeritus
koo beans
Old Mar 28, 2006 | 06:53 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">Also, the filters I tested, made zero difference in anything, peak power or area under the curve. </TD></TR></TABLE>
Ok, tell me what filters you got - cause I need to get a set!
Old Mar 28, 2006 | 07:23 AM
Chugger's Avatar
nice numbers man
how do you like the sound?
Old Mar 28, 2006 | 07:49 AM
Nick M's Avatar
Default Re: (Chugger)
Its alittle, uh, louder
I'll find the link to the filters.
Old Mar 28, 2006 | 07:57 AM
Nick M's Avatar
Default Re: (Nick M)
http://www.cas4.com/Carburetor....html
Velocity Booties
I dont know how much they actually filter, but they didnt make any difference on the dyno.
On the road, I cant say yet.
Old Mar 28, 2006 | 08:32 AM
98vtec's Avatar
moderator emeritus
i was going to run those.....but opted for cheaper ones, lol.
Old Mar 28, 2006 | 10:46 AM
808_si's Avatar
nice numbers, that thing must be quick!
Old Mar 28, 2006 | 11:11 AM
Professor15's Avatar
damn that header n head are choking power big time. Any plans for the future with this motor? Nice build.
Old Mar 28, 2006 | 11:12 AM
Nick M's Avatar
Default Re: (drchulo)
not in the immediate future
maybe a header and bigger exhaust next winter
Old Mar 28, 2006 | 04:06 PM
JCushing's Avatar
i really really hate to be one of these people but i kinda expected higher numbers.... considering 200/148 hp is doable with itr cams and no itbs.... i dunno maybe if i see the graph.. maybe the stock b16 ports simply wont flow any more air...
Old Mar 28, 2006 | 04:17 PM
Nick M's Avatar
Default Re: dyno results, my b20vtec, twm itbs, a video too! (JCushing)
its a b16b head
old setup had an AEBS IM, bbk 70mm tb and 350cc injectors and made 191whp and ran a 12.4
i picked up 19whp and 11ft/lbs with the ITB's and injectors
dont know what to tell u, different dynos, different days, different places...hard to compare
Old Mar 28, 2006 | 04:19 PM
UNKNOWN_MEMBER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">i really really hate to be one of these people but i kinda expected higher numbers.... considering 200/148 hp is doable with itr cams and no itbs.... i dunno maybe if i see the graph.. maybe the stock b16 ports simply wont flow any more air... </TD></TR></TABLE> sounds like he didnt want to rev his car too high. we all know skunk2 makes power all the way up there.
Old Mar 28, 2006 | 04:26 PM
98vtec's Avatar
moderator emeritus
thats what i been trying to tell people. Its literally impossible to compare numbers from other motors nowadays. As long as it performs the way it should...thats all that matters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">its a b16b head
dont know what to tell u, different dynos, different days, different places...hard to compare</TD></TR></TABLE>
Old Mar 28, 2006 | 04:28 PM
Default Re: dyno results, my b20vtec, twm itbs, a video too! (98vtec)
192hp 12.4 that's impressive.
Old Mar 28, 2006 | 04:31 PM
98vtec's Avatar
moderator emeritus
Default Re: dyno results, my b20vtec, twm itbs, a video too! (UNKNOWN_MEMBER)
hey nick....do you have a comparison between your old setup and the setup with the ITB's?
I'd like to see where most of your power was gained.......
Old Mar 28, 2006 | 04:38 PM
DIFFUT'S INC.'s Avatar
nice
Old Mar 28, 2006 | 06:05 PM
BearsEK-KMSU's Avatar
Default Re: dyno results, my b20vtec, twm itbs, a video too! (DIFFUT'S INC.)
Looks like he needs the secret,(smsp)
Old Mar 28, 2006 | 06:10 PM
vtecspeed1320's Avatar
Shooting Star
Id say thats some nice numbers and nice setup.
Old Mar 28, 2006 | 07:11 PM
JCushing's Avatar
i understand that each dynos different.... good to see you picked up that much power though with ITB's im honestly really supprised at that! its tough to judge a dyno by peak numbers though... the graph says alot more....
oh adn those times
Old Mar 28, 2006 | 09:05 PM
mrbsponge's Avatar
very impressive
Old Mar 28, 2006 | 10:21 PM
Kouki-EK9's Avatar
Graph:
coming soon
ban
Can't wait to see the graph.
Old Mar 29, 2006 | 04:06 AM
Nick M's Avatar
Default Re: dyno results, my b20vtec, twm itbs, a video too! (Kouki-EK9)
sorry guys, had no time last night to do anything
pics and graphs soon
