switching final drives
Old Mar 28, 2006 | 05:14 AM
tegman85's Avatar
Default switching final drives
i am quite a noob when it comes to tranny's, other than just switching them out. my question is are final drives interchangable. like can you take a 4.400 final drive out a b16 or so and put it in a ls tranny? thanks for any help.
Old Mar 28, 2006 | 10:40 AM
BOOSTED RIVAL's Avatar
Default Re: switching final drives (tegman85)
Yes you could a b16 final and the ls final is the same size of the ring so it will fit no problem. I did that to my tranny I got a ls quaife lsd in it and I swap in a b16 final gear and it work . The GSR final is different in the ring size.
Old Mar 29, 2006 | 01:02 PM
tegman85's Avatar
what about the type r 4.785?
Old Mar 29, 2006 | 01:32 PM
ITA50's Avatar
The truth is yes and no. An American 90-91 LS integra s1 transmission has a defined shaft diameter size. This diameter is the same size as most JDM S1 shafts which means they can share gears. I on the other hand had an American 92-93 LS Integra YS1 transmission which has a different shaft size. Simply put my gears did not fit on the 4: 4 shaft I got from a friend. The guys at Speed Gear is a good place to start as they seem to be the experts in this area. Good luck.
Old Mar 29, 2006 | 08:30 PM
tegman85's Avatar
thanks for the info
myEKsedan
Transmission & Drivetrain
Sep 19, 2012 01:50 PM
t3601
Jan 19, 2010 04:48 PM
boostedteg1203
Nov 15, 2009 07:23 PM
WhiteEKgsr
Dec 12, 2008 06:45 PM
crazy_eddy
Jun 5, 2008 11:31 PM
