what causes rust in the rear of civics/crx's ?
Old Mar 28, 2006 | 02:47 AM
CRX MASE's Avatar
Default what causes rust in the rear of civics/crx's ?
Old Mar 28, 2006 | 02:58 AM
firebane's Avatar
Default Re: what causes rust in the rear of civics/crx's ? (DavilleKy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavilleKy &raquo;</TD></TR><TR><TD CLASS="quote">???</TD></TR></TABLE>
reach inside the fender and you'll notice that there is a piece of trim that goes around the inside; thats your culprit.
Nobody ever cleans behind there or behind that strip and it collects dust and moisture and voila, rust.
Old Mar 28, 2006 | 03:55 AM
yellowrexsi's Avatar
Default Re: what causes rust in the rear of civics/crx's ? (firebane)
^^^^ good info.
And this whole time I thought it was gremlins
Old Mar 28, 2006 | 04:17 AM
3s0n3's Avatar
that metal lip that he's talking about has a rubber trim peice on it. dirt and water get trapped in it and it never gets cleaned like he said and some idiots even take off the rubber thing and bend the lip up so the 17" wheels wont rub thus weakening it and also creating a pocket for dirt and leaves to sit in and just rott away....
Old Mar 28, 2006 | 04:28 AM
CRX MASE's Avatar
Default Re: (3s0n3)
would this be it? I pulled it out this morning.
Old Mar 28, 2006 | 05:03 AM
user 72830283's Avatar
yup..that looks like it..
Old Mar 28, 2006 | 05:16 AM
CRX MASE's Avatar
Default Re: (pr3d)
hmmm, just think if people would have pulled these out 10 years we wouldnt be fighting the rust battle now lol
Old Mar 28, 2006 | 05:32 AM
ChrisSpade's Avatar
Default Re: (DavilleKy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavilleKy &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, just think if people would have pulled these out 10 years we wouldnt be fighting the rust battle now lol</TD></TR></TABLE>
Ya but thats just half the battle. It comes down to people maintaining and cleaning their car on a regular basis.
Old Mar 28, 2006 | 05:33 AM
mycrx7's Avatar
they have shitty drainage spots on the rear fender whells, pretty much any crx i see now has cancer spots on it unless its already been patched.
Old Mar 28, 2006 | 05:39 AM
CRX MASE's Avatar
Default Re: (mycrx7)
is there anyway to stop it completely?
Old Mar 28, 2006 | 05:47 AM
mycrx7's Avatar
yea u either have to grind out all the rust and patch it in with bondo, or if its bad enough the whole lip and about an inch or more up on the fender can be cut off and a new one welded in its place.
Old Mar 28, 2006 | 06:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 &raquo;</TD></TR><TR><TD CLASS="quote">yea u either have to grind out all the rust and patch it in with bondo, or if its bad enough the whole lip and about an inch or more up on the fender can be cut off and a new one welded in its place.</TD></TR></TABLE>
i'm sure a lot of people will object to your bondo option, as it doesnt entirely work....
or like you mentioned...best option is to find a donor crx with good quarter panels, and just cut the metal out weld it in..and re paint...the only way to get rid of rust for good...but to come across a good donor car for parts is just as rare as finding a crx w/o rust to begin with
Old Mar 28, 2006 | 06:10 AM
mycrx7's Avatar
Default Re: (pr3d)
you dont need to get a donor crx, any quality body shop can do it, and as for the bondo i had rust on my 89 si on the left rear quarter panel, i used this stuff thats supposed to eat the rust and just washed it out, bondo'd the hole in and sanded it flat, flush and smooth with my car looks great and still is holding up awesome, just the red i used to touch it up didnt quite match as well.
Old Mar 28, 2006 | 06:21 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
I don't have any rust on my rears on my 90 crx... what should I look for/do to keep it this way?
p3
Old Mar 28, 2006 | 06:30 AM
SSJSubgeta's Avatar
take care of it like a baby, im serious!
Old Mar 28, 2006 | 06:45 AM
Default Re: (SSJSubgeta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSJSubgeta &raquo;</TD></TR><TR><TD CLASS="quote">take care of it like a baby, im serious!
I meant in reference to the rear wheel wells... =P
Old Mar 28, 2006 | 07:00 AM
neomnj's Avatar
i have a nice size cancer spot on my civic that i need to have taken care of it goes all the way through which pisses me off cause now i gotta see how much replaceing the whole section will be. ive heard it can be up to 2 gs
Old Mar 28, 2006 | 07:10 AM
Rob.'s Avatar
Default Re: (neomnj)
MINE IS NICE AND CLEAN.
Old Mar 28, 2006 | 08:59 AM
crxforum's Avatar
Default Re: (Rob.)
Allright Rob. Everytime you post pictures or mention your Civic or CRX Im going to post mine up. It will be a block to stop the whoring.
Back on topic yes that inner piece is was causes the rust back there. The water / salt gets caught there and then travels back to the end of the wheel well and stays there with no place to go other than in or out. Since the seal is most likely installed correctly it cant go out so it slowly eats away the inside untill it starts to rust through. Its a horrible thing that EF and EG owners have to deal with. IMO its worth it though because you get such a great car otherwise.
CRX Forum
Old Mar 28, 2006 | 09:04 AM
Tippyman's Avatar
Default Re: (crxforum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">
Back on topic yes that inner piece is was causes the rust back there. The water / salt gets caught there and then travels back to the end of the wheel well and stays there with no place to go other than in or out. Since the seal is most likely installed correctly it cant go out so it slowly eats away the inside untill it starts to rust through. </TD></TR></TABLE>
so should I remove it pronto?
Old Mar 28, 2006 | 09:11 AM
madmanmulligan's Avatar
I hate u guys with good fenders here is my project today since its nice out
Sanding, sanding, sanding, and sanding I will do
Old Mar 28, 2006 | 09:15 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">Allright Rob. Everytime you post pictures or mention your Civic or CRX Im going to post mine up. It will be a block to stop the whoring.
[</TD></TR></TABLE>
Its to show off those gay *** rims.
You can also get sheetmetal and bend and contour it to fit, me i replaced the quarters with new oem honda, 450 a side , but hey if u love it you must pay.
Old Mar 28, 2006 | 09:18 AM
Tippyman's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
so should I remove it pronto?</TD></TR></TABLE>
Old Mar 28, 2006 | 09:19 AM
crxforum's Avatar
Depends on where you live. If you live in areas with salt or sand it would be best to do so. The sand will rub back and forth in there exposing metal and water will cause it to rust. The salt will just eat away at it. If you live in Cali or a place like that it shouldnt be a problem.
CRX Forum
Old Mar 28, 2006 | 09:27 AM
Nisif's Avatar
Default Re: (Boosted Chemist)
You can also get sheetmetal and bend and contour it to fit, me i replaced the quarters with new oem honda, 450 a side , but hey if u love it you must pay.</TD></TR></TABLE>
There's also a site that sells the rear wheelwell arches for 88-91 civic/crx. Covers basically past the point where the rust is commonly at on the rear wells. I have the link on my other computer. They're only $40 a piece and they're brand new metal. Better than dropping that much on whole qtr panels, unless the rust is everywhere
