LS/VTEC set-up?*Searched* need answers asap
Old Mar 27, 2006 | 09:54 PM
Jay.D.Em!'s Avatar
Default LS/VTEC set-up?*Searched* need answers asap
I've searched but couldn't find the exact answers i was looking for, I just want to know, Is it possible that i could use a gsr crankshaft, gsr eagle rods, gsr cp pistons(11:5), in a B18a1 block, with a B16a head (obd1 distributor), and B16 cams and cam gears, and gsr transmission (all going into a 1994 integra)? i know it might not be the best set-up, but i just want to know if its possible, and will it run? this is the setup i have now and i want to get it running in my car soon.. i am still ordering the other parts like ecu, axles, vtec conversion kit, and all other small parts needed, but as far as the parts listed above? will it work? thanks for your help
Old Mar 27, 2006 | 10:04 PM
Jay.D.Em!'s Avatar
Default Re: LS/VTEC set-up?*Searched* need answers asap (Saved_Sol)
let me also add that im not looking to make this a track car, its going to be my daily driver for a little while.. and i know your gonna say "well why the high compression then?" but i got the motor and all the parts out of a deal with a friend.. so im trying to get this thing running in good time..
Modified by Saved_Sol at 9:45 AM 3/28/2006
Old Mar 28, 2006 | 01:10 AM
StrokeDC2's Avatar
yes its possible
Old Mar 28, 2006 | 08:45 AM
Jay.D.Em!'s Avatar
Default Re: (StrokeDC2)
thanks..bump
Old Mar 28, 2006 | 09:04 AM
hAILO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saved_Sol &raquo;</TD></TR><TR><TD CLASS="quote">I've searched but couldn't find the exact answers i was looking for, I just want to know, Is it possible that i could use a gsr crankshaft, gsr eagle rods, gsr cp pistons(11:5), in a B18a1 block, with a B16a head (obd1 distributor), and B16 cams and cam gears, and gsr transmission (all going into a 1994 integra)? i know it might not be the best set-up, but i just want to know if its possible, and will it run? this is the setup i have now and i want to get it running in my car soon.. i am still ordering the other parts like ecu, axles, vtec conversion kit, and all other small parts needed, but as far as the parts listed above? will it work? thanks for your help </TD></TR></TABLE>
This is not a LS/Vtec, this is a poor mans type R with a LS block. I guess "Poorer mans type R".
The whole idea behind LS/V is that you use the crank of the LS. But to answer your question. yes, what you have will work.
Old Mar 28, 2006 | 10:16 AM
Jay.D.Em!'s Avatar
Default Re: LS/VTEC set-up?*Searched* need answers asap (hAILO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAILO &raquo;</TD></TR><TR><TD CLASS="quote">
thanks man i appreciate it.
Old Mar 29, 2006 | 05:27 AM
hondaluva's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAILO &raquo;</TD></TR><TR><TD CLASS="quote">This is not a LS/Vtec, this is a poor mans type R with a LS block. I guess "Poorer mans type R".
The whole idea behind LS/V is that you use the crank of the LS. But to answer your question. yes, what you have will work.</TD></TR></TABLE>
He's right with the gsr crank and rods your defintley gonna lose some torque. That's one of the major reasons behind ls/v. But sometimes you gotta work with what you got. It just will not really be considered a ls/v but it will work.
Old Mar 29, 2006 | 06:24 AM
LSracing94's Avatar
Default Re: LS/VTEC set-up?*Searched* need answers asap (hondaluva)
how much of a difference will it really make?..if he is using 11.5:1 pistons that are meant for a GSR will he yeild that compression right??..just lose a little bit of torque thats all..
Old Mar 29, 2006 | 06:30 AM
FATBOYeg6's Avatar
Default Re: LS/VTEC set-up?*Searched* need answers asap (LSracing94)
if they are 11.5:1 GSR pistons, thats the compression they will be with a GSR crank, correct?
Old Mar 29, 2006 | 06:32 AM
LSracing94's Avatar
Default Re: LS/VTEC set-up?*Searched* need answers asap (FATBOYeg6)
thats what he says, why would he techinally lose torque though?
Old Mar 29, 2006 | 03:16 PM
hAILO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">thats what he says, why would he techinally lose torque though?</TD></TR></TABLE>
put it shortly, torque is altered by the length of the stroke not the CR, longer stroke + same compression = more torque
Old Mar 29, 2006 | 05:41 PM
LSracing94's Avatar
worrrrd
Old Mar 29, 2006 | 10:08 PM
Jay.D.Em!'s Avatar
yea the gsr crank with the gsr rods will be yeilding a shorter stroke to my knowledge..damnit i love this site.. ive learned so much
katanamast279
Aug 18, 2009 10:21 AM
1994delsolLS
Aug 24, 2008 02:52 PM
Jay.D.Em!
Mar 28, 2006 09:19 AM
1SlowSi
Feb 21, 2004 03:38 AM
integraautox
Mar 22, 2003 01:43 PM
