how to: rear brake pad change
Old Apr 3, 2002 | 12:10 PM
magic hat #9's Avatar
Default how to: rear brake pad change
now on to the rear pads. carbotechandie suggested i use axxis ultimate pads versus stock, hopefully he'll chime in and give us a dissertation on the value of axxis pads over stock on the track.
pop off the rear wheel and you see this:
there is a dust shield covering the rear caliper, this must be removed or moved to get to the caliper bolts:
i remove the top bolt (10mm) near the "78" and then bend the bitch out of the way:
the rear caliper. we must remove it completely so take off both top & bottom bolts, 12mm i believe. make sure your parking brake is off or you ain't getting the caliper off:
it takes a few tugs, but the rear caliper will come off. note the different looking piston, we'll get to it shortly. be careful to support the caliper otherwise it will fall and damage your brake lines and parking brake cable:
the rear pads pop out of their brackets just like the front pads, there are 2 pads:
here is what we're using:
here is the funky looking piston, it works like a screw - press the brakes and the "screw" tightens against the brake pads and you stop. you can't simply press in the piston, it must turned clockwise to create clearance for the new pads.
it's hard to see, but i use a 1-1/2" wide grout spatula to turn the piston. be careful not to tear the rubber boot around the piston:
put everything back together like you found it. torque the caliper bolts to 16ft/lbs (i use 20ft/lbs, the lowest setting on my wrench). bend the dust shield back into place and bleed a little out of the caliper.
Old Apr 3, 2002 | 12:15 PM
Willard's Avatar
Default Re: how to: rear brake pad change (monkey_truckR)
*note... make sure the "X" shape is at a 90 position.
That will allow the piston to mate with the little tab on the back side of the new pad (if the pad has a tab).
Will
-who has a set of rear pads that are worn at 30 deg. angle...
Old Apr 3, 2002 | 12:19 PM
Default Re: how to: rear brake pad change (Willard)
damn, forgot about the little tabs. is there anyway to check without taking everything apart again? i already brought all my tools in (2nd floor) and it's raining out.
Old Apr 3, 2002 | 12:24 PM
sackdz's Avatar
tear, tear :*(
lol j/k, well if you're gonna do it, do it right
Old Apr 3, 2002 | 12:39 PM
nfn15037's Avatar
Default Re: how to: rear brake pad change (sackdz)
Nice pictures, but whats with all the how-tos today?
Old Apr 3, 2002 | 12:41 PM
RATEDR's Avatar
I run the Ultimates front and rear and they are awesome for daily, auto-x and *light* track use. They bite real well!
to andie at Carbotech as well.
Old Apr 3, 2002 | 12:42 PM
Default Re: how to: rear brake pad change (nfn15037)
it's my day off, i work weekends so i'm off during the week. that, and i have my first ever track event this saturday at limerock!!! i'm a helpful ******* guy!
Old Apr 3, 2002 | 12:47 PM
Kamil's Avatar
Yeah, cuz the Helm's manual is so unclear about changing the brake pads.
Just kiddin there Monkey's_455, see ya on Friday... I might be crashing over at your place in case Matt hasn't told you yet.
Yeah, i got to get my car ready too... uhmm... oil, brake fluid, air in tires, gas... ok, done.
Old Apr 3, 2002 | 12:48 PM
Willard's Avatar
if the caliper was easy to put back on... the pads don't have the tab... or the groove was in the right place..
Will
Old Apr 3, 2002 | 12:51 PM
Default Re: how to: rear brake pad change (Kamil)
damn you, kamil! if you want to see a better sports car for under $40k, look at the ******* type r in my driveway, bioche!
haha, that's cool, you can crash here anytime. matt will be out of town so you can use his bed. i think davidnyc will be here too.
Old Apr 3, 2002 | 12:58 PM
thanks, *****. i just checked the set of axxis pads i got for lanceh, no tabs. also, the caliper slid back on easily. i'm in good shape!!! cool, cause i was about to head back out into the rain.
Old Apr 3, 2002 | 01:16 PM
davidnyc's Avatar
Send me an email, I will most likely crash at your place on Friday.
Old Apr 3, 2002 | 01:45 PM
sackdz's Avatar
Good to hear
Old Apr 3, 2002 | 05:32 PM
Philbert's Avatar
how do you "bleed" the brake fluid? why is this necessary? have you had any trouble not adding the molycote grease? i called my local dealer and the parts guy said they don't sell the grease alone... it comes with the stock pads. do i really need to try and track this stuff down?
thanks,
phil
Old Apr 3, 2002 | 05:45 PM
Raz1983's Avatar
Default Re: how to: rear brake pad change (Philbert)
its necessary cause air can be in the hose, and when you need to use your breaks bad.....woops? huh? no breaks? bang! ouch! byebye type r
anyway, its to take out the air out of your hose.
Old Apr 3, 2002 | 06:44 PM
Leftlaner's Avatar
Wow, you did us this service on your day off? Thanks for the brake tutorial and the pics. Just remember, not all of us are expert parts swappers.
Good luck this weekend, and have fun!!!!
Old Apr 3, 2002 | 06:49 PM
Default Re: how to: rear brake pad change (Leftlaner)
i very much enjoy working on the car, so i'm happy to post this stuff up.
i didn't put on any molycote, but i didn't have any problem with the brakes squealing. there was only a slight noise under hard braking during break-in.
Old Apr 15, 2002 | 05:52 PM
comptechgsr2000
Guest
Posts: n/a
Directions were perfect! Thanks!
Old Apr 15, 2002 | 06:04 PM
BudMan's Avatar
Default Re: how to: rear brake pad change (comptechgsr2000)
If you don't get that tab in the groove properly, be prepared to wear your pads uneven & VERY quickly....
Nice job documenting - NOTE: it can be helpful to remove the master cylinder resevoir cap before trying to move the piston back.
Old Apr 15, 2002 | 06:50 PM
Chris's Avatar
Default Re: how to: rear brake pad change (BudMan)
Hmmm, I always have to remove the E-brake cotter-pin and cable..
Old Apr 15, 2002 | 07:28 PM
Willard's Avatar
jes... my first reply was to warn of that issue...
Will
-who learned the hard way...
Old Apr 15, 2002 | 07:41 PM
Floyd's Avatar
Will
lol, I've been there too.
I also find it usefull to remove the bolt that holds the brake line in place on the lower suspension arm. I've never had to remove the e-brake line, but some times it is a bear getting the caliper off the rotor. Maybe that would help
Old Apr 21, 2002 | 10:31 AM
comptechgsr2000
Guest
Posts: n/a
Default Re: how to: rear brake pad change (Floyd)
Does it matter if I use the high temp Honda brake grease or the orange goo stuff?
Old Apr 21, 2002 | 11:27 AM
Type Goch's Avatar
New User
Orange Goo? Just use some off-the-shelf Anti-Seize
Old Apr 21, 2002 | 12:11 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: how to: rear brake pad change (Type Goch)
Thanks!
