Do you need an alignement after removing axles for a swap?
Old Apr 3, 2002 | 11:55 AM
AMChev's Avatar
Default Do you need an alignement after removing axles for a swap?
I'm guessing that since you are messing with the suspension parts to get the axles out that you would need to have an alignment after you get everything back together.
Old Apr 3, 2002 | 01:02 PM
Kataku2K3's Avatar
Default Re: Do you need an alignement after removing axles for a swap? (cspu)
Don't know for sure if you need to, but i have done many swaps for my friends taking axles and suspension in and out an none of them have had to have their cars realigned after. If their alignment was off to begin with then it seemed to stay the same and if it was good to begin with it was fine after!!!!!! I don't really see why you would need to tho.
Old Apr 3, 2002 | 01:20 PM
Crazydave's Avatar
Default Re: Do you need an alignement after removing axles for a swap? (JDMspecEG6)
Yeah I would get an alignment after taking axles out..
you are taking apart some of the front suspension..
I would definetelly get an alignment after doing a motor swap..
it has a different weight which means a differnt ride height which means a different toe setting.
Old Apr 3, 2002 | 04:19 PM
StorminMatt's Avatar
Default Re: Do you need an alignement after removing axles for a swap? (Crazydave)
Engine swapping (at least B-motors) also seems to have a profound effect on camber. With both of my cars, I have a serious negative camber problem. This rapidly wears the inside edges of tire tread while leaving the outside edge untouched. In fact, unless you look underneath, you would swear the tires are brand new! This is particularly a problem on the driver's side( where the weight of the driver probably adds even more negative camber). A camber kit is definitely in order.
Old Apr 4, 2002 | 01:00 PM
frankdatank's Avatar
alignment is needed. not only are you taking apart the front suspension, but you have added weight in the front end.
Old Apr 4, 2002 | 01:11 PM
mugen175's Avatar
Default Re: Do you need an alignement after removing axles for a swap? (hybridcoupe97)
yup after i did my swap i noticed my car was steering straight...off i went to brake check to get my car aligned.
wesk18
Jan 31, 2008 12:16 AM
sony224422
Aug 28, 2007 07:40 PM
teggytegteg
May 16, 2004 11:41 PM
sting94112
Feb 3, 2004 04:09 AM
rioninja
Apr 18, 2001 03:14 PM
