Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
HID's?
Old Mar 27, 2006 | 05:59 PM
TRAG's Avatar
Default HID's?
Where is everyone getting there HID bulbs from for the 2006 Si? Ive seen pictures of some with the HID's and think it looks great and want to get some...is it just the bulb from the TSX, because thats what i think im seeing.?
Old Mar 28, 2006 | 07:06 AM
jizzlesmizzle's Avatar
i know that both caveman and sean jean are using the tsx projectors...i believe that is what i am going to do to. they have the best color because of them not being fresno
Old Mar 28, 2006 | 08:53 AM
TRAG's Avatar
Default Re: (jizzlesmizzle)
If i wanted to so this TSX HID conversion...is all i need the bulbs or would i need the entire head light unit?
Old Mar 28, 2006 | 09:00 AM
Default Re: (TRAG)
well you can NOT just put the bulbs in your original headlight. you have to have other parts such as ballast, projectors, and bulbs....check out some other post on here and try looking at hid planet. maybe that will give you some idea of what all it takes.
Old Mar 28, 2006 | 09:03 AM
TRAG's Avatar
alright man, thanks, appreciate it.
Old Mar 28, 2006 | 09:54 AM
dontbother's Avatar
I'm going with TSX too. You can't get much better than the TSX projector. It's the best for the money.
Old Mar 28, 2006 | 10:31 AM
eg360B's Avatar
Default Re: (dontbother)
Factory HID" Kits go for alot of money.. I seen a company sell whole kits for lke 350 shipped here on Ht.. Or 250.. I forgot. But yea You cant just plug the bulb in.. Need a Blast Box
Old Mar 28, 2006 | 10:49 AM
Declectic's Avatar
Default Re: (Byrd Gang 021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byrd Gang 021 &raquo;</TD></TR><TR><TD CLASS="quote">Factory HID" Kits go for alot of money.. I seen a company sell whole kits for lke 350 shipped here on Ht.. Or 250.. I forgot. But yea You cant just plug the bulb in.. Need a Blast Box</TD></TR></TABLE>
on hidplanet, they sell the following -
(2) Bosch Projectors
(2) Hella/Philips LVQ-212 G3 Ballasts
(2) D2S HID Bulbs
(2) Ballast Covers/mounts
(2) Ballast connectors
Price $399.99 + shipping
all you would need at that point is [A.] extra headlights (optional) [B.] a conversion harness (or make your own) [C.] and the skills do DIY
Modified by SeanJohn1802 at 12:01 PM 3/28/2006
Old Mar 28, 2006 | 11:24 AM
eg360B's Avatar
Default Re: (SeanJohn1802)
http://hondamarketplace.com/zerothread?id=1480768
Old Mar 28, 2006 | 11:30 AM
zx3tunr's Avatar
I picked up a HID kit from http://www.oznium.com
Old Mar 28, 2006 | 11:36 AM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byrd Gang 021 &raquo;</TD></TR><TR><TD CLASS="quote"> http://hondamarketplace.com/zerothread?id=1480768 </TD></TR></TABLE>
fake *** HIDs
Old Mar 28, 2006 | 07:35 PM
TRAG's Avatar
So how much would the TSX HID conversion run me...any idea?
Old Mar 28, 2006 | 10:13 PM
Declectic's Avatar
Default Re: HID's? (teamelite69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamelite69 &raquo;</TD></TR><TR><TD CLASS="quote">hey i know some places where u can get some HID 9006 headlights for the SI but most places you need to cut the wires on the stock harness and it would void the warentee..if ur interested let me know and ill get u that site.</TD></TR></TABLE>
who said you have to cut the stock wire harness? I got a conversion harness from xenondeopot.com that allows you to just plug and play.. only cutting up would be to retrofit the HID projectors
if the bulb is 9006, it is not HID ... it is simple regular lights with more watts pushed through them to make them brighter than they need to be
Old Mar 29, 2006 | 08:40 PM
SlowTeg's Avatar
Default Re: HID's? (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">who said you have to cut the stock wire harness? I got a conversion harness from xenondeopot.com that allows you to just plug and play.. only cutting up would be to retrofit the HID projectors
if the bulb is 9006, it is not HID ... it is simple regular lights with more watts pushed through them to make them brighter than they need to be</TD></TR></TABLE>
Umm.. do you even know what the hell you're talking about? These ARE HID's. The "hid kits" sold by catz, etc. are TRUE hid's. They create hid bulbs molded into a 9006 shape so u can pop it in ur headlight. The ones shown in that link do in fact look real, just of crap quality. Unless the stock headlight has a half decent projector (which civics don't), don't waste your time w/ a plug and play kit. The beam pattern will look like **** unless you retrofit some nice hid projects (like the tsx) in the civic headlights.
-Mike
Old Mar 29, 2006 | 09:12 PM
Declectic's Avatar
Default Re: HID's? (SlowTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowTeg &raquo;</TD></TR><TR><TD CLASS="quote">Umm.. do you even know what the hell you're talking about?</TD></TR></TABLE>
i happen to think so
my TSX retrofit (still in the works)
if there isn't an HID projector involved, then it ain't HID to me
Old Mar 29, 2006 | 09:27 PM
SlowTeg's Avatar
Good luck on your project first off, nice to see good retro headlights..
Anyway... just because you're doing a retrofit doesn't make you the hid guru. The kit someone posted on honda marketplace for ~$250 does use actual hid bulbs, w/ ballasts, etc. So technically, it does use real hids. Like I said though, it just looks like a POS kit. Catz sells 9006/H4/etc. hid kits which are pretty much plug-in hid's. They are REAL hid bulbs/ballasts, etc. These looked very nice on my old integra. The best way of course is to use a nice projector designed for hids for a perfect beam pattern, but sometimes these hid kits turn out ok, not great.
-Mike
Old Mar 29, 2006 | 10:57 PM
civicvtec1ps's Avatar
PNP kits are not worth money.
Do it right on first time, Retrofit.
Old Mar 29, 2006 | 11:01 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowTeg &raquo;</TD></TR><TR><TD CLASS="quote"> but sometimes these hid kits turn out ok, not great.
I guess i can agree to that i'm just not a fan of them, would rather get the real deal happenin
Old Mar 30, 2006 | 02:32 AM
Otherguy's Avatar
NASIOC.com
Default Re: HID's? (TRAG)
I have an HID kit for the lows and my fogs... its looks great btw... But yeah, i have seen retros on the eg, they do look alot better, but if you want to save the trouble of moddin your head lights just get a kit... I like how mine look. When i get home to the states i will take pictures
Old Mar 30, 2006 | 02:50 AM
1turbodc2's Avatar
if u want to do a retro fit, check out the guyz at http://www.customlightz.com they did my s2k retrofit, with color mod, and some other goodies, they are amazing and some of the best customer service
Old Apr 1, 2006 | 10:02 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (1turbodc2)
Thanks bro for putting us out there.
Though, I realize that the forum is for the newer Civics here is a recent retrofit we did for a 2000 CTR headlights This is from https://honda-tech.com/zero...ge=36
Washer modded S2000 projectors w/ Custom Shrouds.
The daytime running lights is able to do it's job as well...look for the little hole/bulb on the side of the shroud...made enough room for it. Completely sealed and flush in the back...
We are in the middle of a 2006 Civic Si retrofit...I could send a link on this topic to the appearance forum once it's done.
Thanks
Old Apr 3, 2006 | 11:48 AM
Declectic's Avatar
Default Re: (-Bionic-)
yeah, or buy a conversion harness from this guy too!!!!!!!!!!!! lol (sorry forgot your website until mentioned above)
can't wait to see what you guys do for the retrofit! hurrah with that link!
Old Apr 4, 2006 | 04:43 PM
r3v's Avatar
r3v
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote"> if there isn't an HID projector involved, then it ain't HID to me </TD></TR></TABLE>
i'll have to agree. I hate it when people install HID kits with the the projectors. The lighting needs to have a cut off.
Old May 3, 2006 | 07:07 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, or buy a conversion harness from this guy too!!!!!!!!!!!! lol (sorry forgot your website until mentioned above)
can't wait to see what you guys do for the retrofit! hurrah with that link!</TD></TR></TABLE>
As promised here is a sneak peak of the setup.
Old May 3, 2006 | 09:19 AM
Type X's Avatar
PM sent
