DOHC ZC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteonwhiteEF »</TD></TR><TR><TD CLASS="quote">im looking for a stroker kit for my dohc zc does anyone know where i might be able to get one if not if not what internals do you recommend....
</TD></TR></TABLE>well im not sure if there is a "kit (i didnt say it doesnt exist) but i dont know of any...just use d-series parts. when i got my pistons for my zc...... i looked at the d-series pistons with the same bore that i wanted on the srp website...which has it's specs, crunched those numbers in the compression calculator (and wala) i went with some y7's (i think) which put me in the low 8's (i know super low...even for boost) and for the rods i went with eagle (again d-series) and you will have to knotch your block for the rod's. if you need help/info pm me
woops saw that your new...you cant pm me (yet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">well im not sure if there is a "kit (i didnt say it doesnt exist) but i dont know of any...just use d-series parts. when i got my pistons for my zc...... i looked at the d-series pistons with the same bore that i wanted on the srp website...which has it's specs, crunched those numbers in the compression calculator (and wala) i went with some y7's (i think) which put me in the low 8's (i know super low...even for boost) and for the rods i went with eagle (again d-series) and you will have to knotch your block for the rod's. if you need help/info pm me
woops saw that your new...you cant pm me (yet)</TD></TR></TABLE>
good info
good info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteonwhiteEF »</TD></TR><TR><TD CLASS="quote">hey thanks man i will let you know if i need help how did the turbo do on the zc every body has something diferent to say </TD></TR></TABLE>yeah no prob
and about the turbo....since i've done my rebuild i've been na.
till im done breaking it in (which sucks because: a) it isnt my daily driver so i dont put many miles on it and b) the comp is real low (8:1) (so i neeeeed booost) but when it was boosted (and stock build) it ran great with the turbo i love how it pulled (and that was a small t25 with no intercooler)...i go to an auto-tech school so i just did a re-build so i can boost the fuc outta it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">
good info </TD></TR></TABLE> thanks man i help when i can (and you always come thru wit the zc info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">good info </TD></TR></TABLE> thanks man i help when i can (and you always come thru wit the zc info
rddyno.com makes a stroker kit for the d16 engine..Its very expensive though and not worth it to me..Im sure there is a way to use a crankshaft from a d17a engine..Dont know though.
SFlCrx
Nov 26, 2007 05:51 PM
