Weight of 98 spec ITR wheels?
Old Mar 27, 2006 | 04:43 PM
TypeRKoncepts's Avatar
Default Weight of 98 spec ITR wheels?
http://shop1.jdmtheory.com/pro...a8c3b
The ones pictured there... i believe they're 98 spec itr wheels. Anyone know how much each weighs?
Thanks
Old Mar 27, 2006 | 05:00 PM
ZygSpeed's Avatar
Default Re: Weight of 98 spec ITR wheels? (TypeRKoncepts)
Looks like they'll be around 17 lbs.
Old Mar 28, 2006 | 10:06 AM
mugenracer's Avatar
I think 16.8lbs is the actual weight...heavy *** compared to the 96spec at 12.3lbs!
Old Mar 28, 2006 | 10:26 AM
realis9's Avatar
Default Re: (mugenracer)
doesn't it all work out to be the same in weight? The jdm 15 weighs 12.3lbs and a good set of 205/50/15 azenis sport weighs 22.5. total weight of 15's plus tire =34.8. Jdm 16's weighs 16.8lbs + pirelli p7000 205/45/16 weights 18lbs. total weight of 16's + tires = 34.8lbs.
Old Mar 28, 2006 | 11:09 AM
gunnis's Avatar
Default Re: (realis9)
http://www.wheelweights.net/
Acura Integra Type-R (US 5-bolt) Cast 15x6 15.6lbs
Acura Integra Type-R (Euro 5-bolt) Cast 15x6 13.0lbs
Acura Integra Type-R (JDM 4-bolt) Cast 15x6 12.3lbs
Acura Integra Type-R (JDM 4-bolt) Cast 16x7 17.0lbs
I've never heard of the last one, nor do I see JDM 5 bolt. ?
Check it out.Good luck
Old Mar 28, 2006 | 12:35 PM
ITR0065's Avatar
Default Re: (gunnis)
I just sent my set to get powdercoated so I can't get exact numbers, but the wheels with 205/45/16 yokahoma es100's were SO close to the weight of my usdm's with 205/50/15 Bridgestone Potenza RE750's. Now I know two diffrent tires, but still, the weight diffrence was so minimal you wouldn't be able to tell which you were holding.
BlueIntegraBoy
May 21, 2009 04:03 PM
itr1882
Sep 22, 2007 06:55 AM
Rishiras
Jul 25, 2006 09:23 AM
shirlenco
May 8, 2002 05:49 PM
Toda Party
Jun 24, 2001 07:42 PM
