Help! crx won't start afer B16 swap
The ecu blinks when I turn it on. All three grounds are hooked up. It has spark and fuel, the firing order is correct. What else could it be.
make sure your timing is correct, and make sure the spark plug wires are going to their correct respective locations. Also, make sure that your battery is charged. Check for voltage at the map sensor as well. gl.
You said your ECU blinks, is it the red light on it? If so, count the blinks (twice, to make sure you dont have 2 or even 3 codes) and check out the codes depending on what OBD you have. It'll tell you why its pissed off and what to fix
I had the same problem have you checked the compression.........also the like efb20 said check out the dizzy and make sure it is working I think it is form what I am reading cause you said you are getting spark so check the comp
iphatcrxi
Oct 19, 2004 04:13 PM
bluedelsol
Feb 16, 2003 05:36 PM
