Fabricate Aluminum block thread?
Old Mar 27, 2006 | 03:46 PM
Turbo-Honda's Avatar
Default Fabricate Aluminum block thread?
Does anyone know of anything I could do to fix a strip head bolt thread?.. Time-sert or Heilicoil of course, but I already did Timesert on it once and the thing strip again over one year of boosting... I heard there a thing you could fill up your headbolt thread and re-tap it. Aluminum? Does anyone know the procedure on how to do it?... I also heard someone said there a thing that you heat up with a propane torch then fill in the block to seal that aluminum. Is that true or it a lie?
Thanks; for any reponses...
Old Mar 27, 2006 | 03:51 PM
ILLICON5000's Avatar
Default Re: Fabricate Aluminum block thread? (Turbo-Honda)
I know permatex makes something called aluminum filler but I think you might want to watch the heat rating. I am in the same boat , next time my manifold comes off I'm gonna need to fix two stripped threads so I would like to know
Old Mar 27, 2006 | 05:13 PM
dfoxengr's Avatar
Default Re: Fabricate Aluminum block thread? (ILLICON5000)
weld and tap.
Old Mar 27, 2006 | 05:52 PM
adictionbass's Avatar
Default Re: Fabricate Aluminum block thread? (dfoxengr)
how do you weld down in there?
Old Mar 27, 2006 | 06:06 PM
dfoxengr's Avatar
Default Re: Fabricate Aluminum block thread? (adictionbass)
use the force
Chance EG
Welding / Fabrication
31
Jul 22, 2015 01:53 PM
Skatnshawn
Mar 24, 2013 12:25 AM
Turbo-Honda
Apr 7, 2006 08:29 PM
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
sgT
Jul 4, 2002 08:31 PM
