Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Bulb Change
Old Mar 27, 2006 | 03:11 PM
Gottaprblm's Avatar
Default Bulb Change
Is it just me or do the headlight bulbs get harder to change as the years progress. I was preparing to install some silverstars and just wanted to make sure that I was able to get to the bulb prior to the purchase. Everything went well until I had to put the coolant resovoir back in its place. It took me forever to line up the insert until finnally I had to take the battery tie down off just so my fat fingers could get in there. Anyone else have any problems?
Old Mar 27, 2006 | 03:36 PM
spoonlongblock's Avatar
Default Re: Bulb Change (Gottaprblm)
my ogre like hands had problems with the ABS actuator and I had to move it by removing the three bolts that hold it in
Old Mar 27, 2006 | 03:46 PM
Caveman74's Avatar
Default Re: Bulb Change (spoonlongblock)
The key to taking the bulbs out... pull 2 tabs off of the wheel well liner. Then pull on it.. you can access them that way.. Much easier
Old Mar 28, 2006 | 06:00 AM
huy1224's Avatar
I had the same exact problem. I tried and tried, and ended up giving up and taking out the battery to put the coolant reservior back in. As for the other side, I took out the actuator cuz I thought it was easier;it was a pain to get the 3 bolts back in. I ended up going through the wheel well too to install the lights...........
Old Mar 29, 2006 | 10:25 PM
96rrated's Avatar
i just have to ask why everyone is going silver stars? i have always used cuzo bulbs and they are bright az **** and great color! just wondering?
wekillyou
Sep 15, 2011 07:07 AM
i-VTEC_DOHC
Mar 10, 2008 02:50 PM
DriveSlowHomie
Jul 31, 2007 05:27 PM
hyogen
18
Mar 13, 2007 12:25 PM
sdsviet
Aug 15, 2004 01:54 PM
