Port & Polish?
Old Apr 3, 2002 | 11:10 AM
-=-'s Avatar
Default Port & Polish?
How much Hp gains can u get from this?
Old Apr 3, 2002 | 11:13 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Port & Polish? (Neutral)
A LOT
Old Apr 3, 2002 | 11:20 AM
JL 74's Avatar
25 Year Member
Default Re: Port & Polish? (B18C-EJ1)
Check with Gran Turismo game. That should give you an idea on what to expect.
Old Apr 3, 2002 | 11:23 AM
-=-'s Avatar
So you get more HP with port & polish than i/h/e right? so why not get port & polish first b4 the i/h/e?
Old Apr 3, 2002 | 11:34 AM
vtec_addict's Avatar
Is this something any machine shop can do? Can I do it myself?
Old Apr 3, 2002 | 11:57 AM
Tweakmeister's Avatar
Default Re: Port & Polish? (vtec_addict)
well, a light job you could do in your garage (just use some sand paper and "polish" the ports).
The real thing requires head removal and to really get power out of it takes a trained hand. http://www.theoldone.com <--- they have pretty pictures
Old Apr 3, 2002 | 01:05 PM
GSR_Hacker's Avatar
New User
Because if you do the p/p before you have the rest of the setup then the airflow will not be suffecient to utilize the improvement of airflow on te head...
P/P is only one PART of a good motor...
Old Apr 3, 2002 | 01:17 PM
TeamTooQuick's Avatar
Default Re: Port & Polish? (GSR_Hacker)
i know it costs a lot 2 have your heads p/p, but can someone tell me that has their head p/p how much it costed u 2 have that done???
Old Apr 3, 2002 | 01:24 PM
Jesse H's Avatar
Default Re: Port & Polish? (TeamTooQuick)
Local machine shop that`s installing my valvesprings quoted me $600. I wasn`t so curious after that since the $600 would cut into my AR-15 fund considerably.
Old Apr 3, 2002 | 01:25 PM
Default Re: Port & Polish? (Jesse H)
dang so it only costs 600??? has n e body else been quoted?? All the people i talked 2 says it would cost me just as much as another motor??
Old Apr 3, 2002 | 01:30 PM
poison's Avatar
Default Re: Port & Polish? (jl74)
is this game that realistic to real car tuning??
if so ima buy it ;x
Old Apr 3, 2002 | 02:21 PM
Default Re: Port & Polish? (poison)
has n e body else been quoted or had their head p/p, im very interested in getting my GSR head p/p, TIA...
Old Apr 3, 2002 | 04:25 PM
anybody?
Old Apr 3, 2002 | 04:39 PM
randyman's Avatar
New User
port and polish jobs will usually run anywhere around 500-900 depending on how good the job is. PORTFLOW does an excellent job when it comes to cylinder heads -- especially honda's.
as far as hp figures, that is sort of a gray area. the hp figures will depend on how much work is done to the whole engine itself. DO NOT expect huge gains with port and polish jobs. u will get minimal gains if the motor is basically stock or just the regular i/h/e. headworks shine when combo'd with force induced applications or N/A applications that carry big cams, big compression, etc.
in sum, try not to compare hp figures with somebody else's or figures from video games -- that is very unrealistic. every engine is different no matter how exact ur combo is to somebody else's. tuning will be ur best bet to get ur optimal hp gains, whether it be a headwork, high compression pistons, cams, and the like.
hth.
Old Apr 3, 2002 | 06:41 PM
Nick's Avatar
Default Re: Port & Polish? (randyman)
I'm pretty sure he was joking about the whole Grand Turismo thing.
gavinoauto
Jul 4, 2008 11:49 AM
Spectrum24x
Oct 20, 2005 07:38 AM
xxxxspdrcr
Jun 19, 2003 10:30 PM
rota426
Mar 14, 2002 09:05 AM
95AccordEXVtec
Sep 20, 2001 10:47 AM
