Pre Build Questions
Im in the process of doing research on what i to buy for my mild gsr build.
The setup im thinking about is:
Portflow GSR Head with Complete BC Valvetrain and Spec 4 Cams
Stock Rods
JDM B16 or JDM ITR Pistons
New ITR Style Intake Manifold
JDM ITR 2.5" Header
T1R Exhaust
ARP Head Studs and Rod Bolts.
My question is what pistons should i use?
Will it be safe to rev to 9k max?
Will i have enough compression to get the most out of the spec 4's?
Are there any other things i should think about changing?
Modified by The Photographizer at 4:50 PM 3/27/2006
Stock Rods
JDM ITR 2.5" Header
T1R Exhaust
With a cam like the BC4, id run at least a P73-00 piston. P30 will do you well also. UPGRADE THE ROD BOLTS if you plan on revving to the sky, and make sure you know that that header will make power, but there's plenty more power to be had with a better header.
Thanks for the input NA. I agree a better header will be in the works but i want to get it built first then buy a baller header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Photographizer »</TD></TR><TR><TD CLASS="quote">Thanks for the input NA. I agree a better header will be in the works but i want to get it built first then buy a baller header
sounds like me
im still rocking the JDM 4-1 on my build
</TD></TR></TABLE>sounds like me
With that motor, adding engine management would be your next step. Put some ARP rod bolts in it, I personally would use the ITR piston, head studs and crome pro/ H-data. After engine management would be a better header and you'll make power. Good luck.
LSD_Rob
Mar 30, 2012 06:31 AM
