Suspension & Brakes Theory, alignment, spring rates....
what else do I need?
Old Mar 27, 2006 | 09:52 AM
lacking vtec's Avatar
Default what else do I need?
First off, I'm a suspension noob. So anyway, I'm about to get the ground control springs and tokico struts for my DA and plan to lower it maybe 1.5"-2". Besides the actual struts, springs and bushings...what else do i need to do and get? thanks in advance.
Old Mar 27, 2006 | 10:11 AM
AutoXer's Avatar
Default Re: what else do I need? (RagingAlcoholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAlcoholic &raquo;</TD></TR><TR><TD CLASS="quote"> springs and bushings...</TD></TR></TABLE>
Are you buying the GC sleves? The springs that GC uses are Eibach Race Springs, and you will need to buy the GC sleeves in order to mount them to the shock.
What bushings are you talking about?
Old Mar 27, 2006 | 10:30 AM
Default Re: what else do I need? (AutoXer)
uhh, the ones for the struts? or can i just use my old ones?
Old Mar 27, 2006 | 10:58 AM
AutoXer's Avatar
If you're talking about the rubber in the mounts, then yes, you can reuse them.
Old Mar 27, 2006 | 11:08 AM
ok, here's what i've been looking at:
http://cgi.ebay.com/ebaymotors...ZWDVW
and these also:
Old Mar 27, 2006 | 07:24 PM
any other inputs? i need to know what else to get if i buy those...
Old Mar 27, 2006 | 07:28 PM
AutoXer's Avatar
You don't need anything else.
I would suggest buying something other than the Blue shocks with the GCs as they are basically a stock replacement. I'd look into the Illuminas or Koni Sports (yellows) although, you could probably get away with the Reds with off the shelf rates.
brideezy
Suspension & Brakes
Aug 23, 2010 07:10 AM
young-richie
Suspension & Brakes
Aug 28, 2007 06:51 AM
tronic
Mar 18, 2005 12:12 AM
mist sITR
Apr 19, 2004 10:26 AM
91ls-v
Feb 26, 2004 07:56 PM
