97 Integra Gsr(340+hp)tuned by Jo-Tech
will put up the dyno sheets by the end of the week or when i run into a scanner
B18C1
all blockwork done by golden eagle
JE 81.5mm 9.1 pistons
Eagle H beam rods
Golden Eagle (godzilla)sleeved block
Skunk 2 valves
Skunk 2 Ti-retainers
HEAD PORTED BY PORTFLOW
TODA dual spings
JG Edelbrock Intake Manifold
VIS carbonfiber Hood
TIEN SS coilover system
DRIVESHAFT SHOP STAGE 5 driveshafts (with hub system)
SKUNK 2 top rear strut bar
DC sports lower rear strut bar
Greddy Oil catch can
SPARCO 4 point harness barr
FALKEN Ziex's(90% tread)
TIAL blowoff Valve
TIAL wastegate
C&R RADIATOR (relocated like civic hatchback)
FAL fans
Mugen Thermostat
Earl's middle pillar bar
JG Edelbrock 65mm Throttle Body
ITR valvecover
R/C 750 injectors
MSD 3bar map sensor
AEM fuel pressure reg.
AEM fuel rail
custom 3'exhaust piping,intercooling piping,
ARP Head Studs
(NEW) Type R Transmission (with LSD)
ACT clutch
ACT flywheel
HASPORT motormounts
Skunk 2 short shifter
HONDATA s-200 unit (tuned by jotech motorsports)
OBD-1 (integ GSR ECU)
AUTOMETER boost gauge
AUTOMETER fuel pressure gauge
Precision SC61 turbo
REV turbo manifold
custom downpipe and dumptube
Stainless oil feed/return lines
Type R 5 lug conversion
Type R wheels
Greddy profec-B turbo timer
Greddy profec-B boost controller
SPARCO steering wheel
SPARCO milano seat (drivers side)
MSD distributor cap
CRANE monster plug wires
full stereo setup
Boston rallys components in fr.
boston sl60 components in rr.
alpine deck
12'JL W3
JL 250 monoblock for sub
JL 300/2 for the components
tell me what you all think
B18C1
Eagle H beam rods
Skunk 2 valves
TODA dual spings
TIAL blowoff Valve
TIAL wastegate
FAL fans
Mugen Thermostat
ITR valvecover
R/C 750 injectors
MSD 3bar map sensor
AEM fuel rail
ARP Head Studs
ACT clutch
ACT flywheel
HASPORT motormounts
REV turbo manifold
Type R wheels
MSD distributor cap
full stereo setup
alpine deck
12'JL W3
very nice. good to see another green teg looking so clean. the motor sounds like a beast. only thing i would do is the 98+ conversion. i think it looks much better than the 94-97, but thats just my opinion. nice car.
what turbo are you using...... and how much psi's ...
well i just going to give you something to compare...
and LS/VTEC 81.25mm 9.8:1 pistons stock head intake and trottle and just a hks drag manifold
... 2.25'' piping with a 60-1 masterpower turbo we get 415 whp @22 psi using uberdata.....
Very nice car OP:
Sorry to sort of thread jack a little, but who has the highest hp integra? I know the top 5 highest hp supras, but i dont have a clue as to who has the highest hp integra?
Modified by RIP Indian Larry at 12:05 PM 3/27/2006
come sept. i might not have it might get rid of it and get a new house Soon
dont have any #'s yet cause i work from 7-6 mon-fri ,dont ever have a chance to bring it out
thinking about bumping the psi to 19 this weekend
i just read that if this isnt tech related i might get banned
so while im at it i do have a question
the tube that runs from the top of my blow-off valve to the back of my intake manifold keeps flying off at high boost (9+psi) what is a good way someone might suggest that i can keep it from flying off every 2-3 pulls
I think you should be making more power....Looks like a good setup. Should be reliable as hell but could easily make alot more power.
Run the 19lbs you were talking about...
I would definantly be pushing more boost with that kind of setup, but keeping it simple is a good idea!
I had the same problem with my charge pipe, just got one of those v-band style clamps and synched it down tightly.
cool thanks for the help ppl.
and ya i could make more power by upping the boost,but i dont take it to the track (cause i work so much) i mainly drive it on the street and if you familiar with driving a little import with 346 horse's you will find out that getting grip is almost impossible with over 14psi unless i take off in 4th gear hehe, one day i will bump the boost high but until i find a place like a track to drive it i'll keep it at cobra eater status
intercooler(rev hard) out of the original stage 2 kits for gsr's not sure the dimensions
bsixteen
May 23, 2006 10:38 AM
i always run around like a fool and yell it out. haha
