Removing my A/C from my CRX
Old Mar 27, 2006 | 08:59 AM
LSV_REX's Avatar
Default Removing my A/C from my CRX
I recently removed my A/C from my CRX and I'm wondering what to do with the plugs that relay to the radiator fans. I read somewhere that the fans won't turn on after removing the AC. I'm in the process of a swap so any input would help. Even if there is another thread where this is covered.
Old Mar 27, 2006 | 09:05 AM
YumVTEC's Avatar
Default Re: Removing my A/C from my CRX (LSV_REX)
your main radiator fan will still turn on, just the smaller AC one will not unless you splice it into the wiring for the other fan. then they will both turn on at the same time.
pm'd you about buying your compressor if you're interested.
Old Mar 27, 2006 | 09:07 AM
Mavrick's Avatar
thats a joke, it has nothing to do with the engine cooling fan. It will disable the a/c cooling fan however cause you removed the AIR CONDITIONING
giovannie23
Feb 28, 2013 12:17 AM
94_civicEx
Honda Civic (2001 - 2005)
Jul 20, 2010 03:32 PM
sleeper1g
Dec 22, 2008 07:15 AM
Arsenal
May 11, 2007 10:29 AM
iGoneRacing_GSR
May 11, 2004 05:11 AM
