215/45 R16's
Old Mar 27, 2006 | 06:50 AM
marc-111's Avatar
Default 215/45 R16's
on civic 96-00 guys!
when you guys make a full turn on your front wheels does it rub on the inner body/fender of your car? any problems for this kinda tires on a rim 16?
thanks!
Old Mar 27, 2006 | 11:43 AM
old man neri's Avatar
Default Re: 215/45 R16's (marc-111)
Stock for your car is 185/65-14
205/45-16 is the best 16" size for your car.
215/45-16 is too wide your car. Get better tires not bigger tires.
Modified by old man neri at 11:40 AM 3/28/2006
Old Mar 27, 2006 | 09:29 PM
marc-111's Avatar
ok thanks!
Old Mar 28, 2006 | 03:59 AM
ErrDizzle's Avatar
I run 215/45-16 azenis' on my spoons just fine on my EK.
Old Mar 28, 2006 | 05:48 AM
Autoworks's Avatar
Default Re: (a_kaibigan)
Actually 205/45-16 is a perfect size to use.
Old Mar 28, 2006 | 06:57 AM
marc-111's Avatar
^^^^ but the new azenis does not have 205/45 16
kaibigan on your spoon whats your offset? and it doesnt rub on your inner wall fender when you make a full turn?
Old Mar 28, 2006 | 09:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (marc-111)
Which model and version Civic (EX Sedan, DX Hatchback, etc)? (Yes, it makes a difference.)
If your car came with 185/65-14 or 195/55-15 tires stock, then you can use either 205/45-16 or 215/45-16.
Old Mar 28, 2006 | 11:17 AM
marc-111's Avatar
Default Re: (nsxtasy)
mine is a 2000 EX coupe
i have a 16x7 offset 42 rims
Old Mar 28, 2006 | 01:46 PM
nsxtasy's Avatar
H-T Order of Merit
Your car came with 185/65-14 tires from the factory. 205/45-16 tires are 0.8 percent smaller (in outer diameter) than 185/65-14, and 215/45-16 tires are 0.7 percent bigger. You should be able to use either one on your car. I want to say they won't rub at all, but kaibigan can tell you for sure.
Old Mar 28, 2006 | 09:33 PM
marc-111's Avatar
ok thanks guys! im buying a 215/45
SUDISTIK ONE
Feb 3, 2011 08:43 PM
Unphzd
Jan 9, 2011 05:51 PM
vancouverdc4
Jun 5, 2007 05:59 PM
Declectic
Sep 17, 2006 07:17 AM
prr
Oct 21, 2002 01:59 PM
