Exhaust Bolt Question
Old Mar 27, 2006 | 06:00 AM
k-series's Avatar
Default Exhaust Bolt Question
I have a 92 RS and I need those spring bolts for the muffler/midpipe section and for the header/cat section. Are those all the same Honda/Acura wise?
My new exhuast didn't come with them.
Steve
Old Mar 27, 2006 | 06:18 AM
DC2 Mang's Avatar
Default Re: Exhaust Bolt Question (k-series)
i think hey are all the same, or atleast have the same fucntion, the allow the header to flew when the motor rocks or moves around
ive seen headers break off at the flange when the springs are not used
im sure you can get then off any 4 cylinder hona at the junkyard
Old Mar 27, 2006 | 06:40 AM
ebonyrolla7's Avatar
the ones at the junkyard are probly rusted to hell though
Old Mar 27, 2006 | 06:52 AM
k-series's Avatar
Default Re: (ebonyrolla7)
Exactly. I'm placing an order at Majestic and figured I could toss in some Honda bolts and springs for my DA.
I need them for the Muffler to midpipe and header to cat section right?
Thanks,
Steve
Old Mar 27, 2006 | 07:15 AM
purplegsr's Avatar
Default Re: (k-series)
You only need spring bolts for the header to cat flange, the bolts connecting the cat to the midpipe and the midpipe to the muffler are regular bolts. So you will only need 2 spring bolts total.
Old Mar 27, 2006 | 07:23 AM
k-series's Avatar
Default Re: (purplegsr)
The exhaust I ordered (Tsudo N1) has a threaded opening on the midpipe to muffler section. None of the other sections do. Is that just a straight bolt? I could have sworn it was spring loaded.
Steve
Old Mar 27, 2006 | 07:26 AM
k-series's Avatar
2002 Civic Si Exhaust - Part 14/15
1993 Civic Hatch DX - Part 29/30
Both are spring bolts.
Steve
Old Mar 27, 2006 | 07:52 AM
purplegsr's Avatar
I have a 92 LS, and it's only 1 set of spring bolts connecting the cat to the header on my aftermarket exhaust. The rest are conventional bolts. The stock system has spring bolts for both the midpipe and muffler, but the flange is a little different than an aftermarket one. I am running an HKS Sport Exhaust, and I am assuming the Tsudo would be set up similarly to the HKS, although I think mine came with conventional bolts for the midpipe-muffler connection. I would buy both types, and see what works best, since the aftermarket flange (flat) is a bit different from the stock exhaust flange (concave).
Old Mar 27, 2006 | 08:31 AM
k-series's Avatar
Default Re: Exhaust Bolt Question (purplegsr)
This muffler section is definitely concave. Looks like springs then.
Steve
madcrossover
Jul 1, 2006 10:31 AM
AirWaveGT
May 28, 2004 07:16 AM
slowacura
May 17, 2004 02:08 AM
SupaTegRS
May 8, 2003 05:33 PM
redGSRguy
Jan 4, 2002 04:45 PM
