Couple of tech questions? 400hp, stock headgasket? Stock cam belt?
Old Mar 27, 2006 | 04:54 AM
djnikko's Avatar
Default Couple of tech questions? 400hp, stock headgasket? Stock cam belt?
I have a couple of questions regarding my engine build, I am aiming for 400hp on a boosted h22.
I have 2 choices (maybe 3) in regards to headgasket, stock thickness cometic headgasket or a motor factors copy of the stock headunit. Or its not too late for me to order the stock honda headgasket but also do not want to waste money if its not really needed.
Your help is much appreciated
Old Mar 28, 2006 | 03:12 AM
djnikko's Avatar
Default Re: Couple of tech questions? 400hp, stock headgasket? Stock cam belt? (djnikko)
bump for some answers
Old Mar 29, 2006 | 11:29 PM
djnikko's Avatar
bump? Just wanna get an idea of whos using these stock parts and getting over 400hp or thereabouts on their setup
Thanks
Old May 24, 2006 | 05:53 AM
djnikko's Avatar
anyone able to help?
Thanks
Old May 24, 2006 | 08:47 AM
b18sihatch's Avatar
i say go with aftermarket timing belt and headgasket
Old May 24, 2006 | 05:29 PM
Race Egr's Avatar
Default Re: Couple of tech questions? 400hp, stock headgasket? Stock cam belt? (b18sihatch)
oem is best
Old May 25, 2006 | 08:40 AM
NITROUSHONDA's Avatar
Default Re: Couple of tech questions? 400hp, stock headgasket? Stock cam belt? (NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">oem is best</TD></TR></TABLE> what he said
Old May 25, 2006 | 11:33 AM
PHDZINE's Avatar
OEM and aftermarket headgaskets (Cometic) will hold over 800+WHP (depending on your tune) but the question is, do you have the piston to head clearance to run a factory headgasket.
The problem with using factory headgasket is that you only have one thickness to choose from. With aftermarket gaskets you can choose your thickness.
The more power you make the more critical it is to have all the right clearances.
With a built block, there are so many variables. Check to see how much the piston hangs out the block because sometimes when the block is decked the piston will hang out a few thousands. You need to make sure you have at least .040 piston to head clearance.
I use Cometic headgasket and a OEM timing belt and I make over 800WHP
Modified by PHDZINE at 9:12 PM 5/25/2006
Modified by PHDZINE at 9:13 PM 5/25/2006
Old May 25, 2006 | 11:44 AM
b18sihatch's Avatar
Default Re: Couple of tech questions? 400hp, stock headgasket? Stock cam belt? (PHDZINE)
now that is just sex
fuzzysig
Engine Management and Tuning
Oct 23, 2016 11:29 AM
b16hybridsol
Jun 21, 2005 05:48 AM
dome
Jun 19, 2005 06:00 AM
danz75
Sep 3, 2004 04:16 AM
EG-cellent
37
Oct 14, 2003 04:00 PM
