CATALYTIC CONVERTER
Old Mar 26, 2006 | 10:52 PM
94~GSR's Avatar
Default CATALYTIC CONVERTER
OK i got my 02 Sensor changed to ( BOSCH Universal ) but i still fail the state inspection...the guy at the garage place told me it might be my CATALYTIC CONVERTER because i been driving my car and the fuel dont really burn that good so it could clog up the CATALYTIC CONVERTER...so im wondering if anybody ever had this problem and maybe you can help me with any Info....
Old Mar 27, 2006 | 03:41 AM
VTteg's Avatar
Default Re: CATALYTIC CONVERTER (94~GSR)
How can you tell that the fuel "doesnt really burn that good"?
Old Mar 27, 2006 | 05:34 AM
Schister66's Avatar
Man U FTW
start by telling us what you have done on your car....i honeslty don't know where else to start....i have never done an emissions test or inspection....
Old Mar 30, 2006 | 12:40 AM
94~GSR's Avatar
well all i ever did to my car so far was changing the DC header,catback,AEM Intake,and Filter,MSD Wire and a Stage3 Clutch...but i dont think these stuff would cause my emission to fail...but afer i fail it i paid the autoshop guy to find out what cause it...so he pluged some kind of stuff under my dash at the passager side to read the problem...he told me that there something wrong with my Heat Oxygen Sensor....
Old Mar 30, 2006 | 01:38 AM
Deluzional's Avatar
Default Re: (94~GSR)
a lot of people have run into emissions failure due to their cat..maybe its time to replace it
Old Mar 30, 2006 | 11:04 AM
94~GSR's Avatar
Thanx alot Deluzional's.....but says if i wanna upgraded now because i needed to replace it anyways...can i get a Hi-Flow or OBX cat?and wouldnt give me any problem for the emission test????
Old Mar 30, 2006 | 11:30 AM
Type_R_Lover's Avatar
dude i had that same problem.... u have to replace the cat converter.. u have too...
Old Mar 30, 2006 | 09:30 PM
94~GSR's Avatar
yea guyz ima change the CAT like what u guys are telling me , and i hope thats the issue im having.........Thanxz
Old Mar 30, 2006 | 11:48 PM
krnboynemesis's Avatar
I have an OBX high flow cat that I never put on my GSR because it would require a custom weld to make it fit my car right. If you wanna try it, I'll give it to you for $20, it's just sitting on my floor and I wanna get rid of it. But do know, I tried to put it on myself and wasn't able to. You'd prolly have to take it to a muffler shop to fit it right.
Or you could do what I did and hollow out your stock cat. I removed mine and took the chisel and hammer to it, removed the filters and carbon blocked up in it, and bolted it back in. Now I essentially have a high flow in the form of a stock cat. But it still won't pass smog.... at least its a little faster.
Default Re: (krnboynemesis)
If you want my OBX one though, email me: notmynamenemesis@hotmail.com. Just lemme know.
Old Mar 31, 2006 | 05:26 AM
Racermech's Avatar
I dont believe the OBX Hi Flow cat, is an actually cat. Most of them are "test pipes" Meaning they just a piece of pipe. So yes you would still fali emissons test with one.
You can pick one jump from a junk yard, or you can just buy a new one. Not too hard to install yourself.
Old Mar 31, 2006 | 05:49 AM
Ichigo's Avatar
get a stock cat for emission and then put a high flow cat on for performance after emissions.
Old Mar 31, 2006 | 06:13 AM
Dogginator's Avatar
Daisy... Daisy...
Check will Acura if there was a recall. My '97 GSR had a recall and they would replace the catalytic converter.
Old Mar 31, 2006 | 06:22 AM
Lan's Avatar
Lan
Default Re: (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">I dont believe the OBX Hi Flow cat, is an actually cat. Most of them are "test pipes" Meaning they just a piece of pipe. So yes you would still fali emissons test with one.
You can pick one jump from a junk yard, or you can just buy a new one. Not too hard to install yourself.</TD></TR></TABLE>
The above statement is true, but you cannot buy catalytic converters from junkyards in CA. I dunno about MA. This is what I have been told.
Old Mar 31, 2006 | 10:52 AM
Racermech's Avatar
Default Re: (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">but you cannot buy catalytic converters from junkyards in CA. I dunno about MA. This is what I have been told.</TD></TR></TABLE>
Wow did not know that.
Old Mar 31, 2006 | 06:56 PM
InfamousDC2FI's Avatar
move to oregon
hon2984
Jun 10, 2008 03:32 PM
vinuneuro
Sep 13, 2007 08:44 AM
danno33
Jun 13, 2007 08:34 AM
headhunter
Oct 29, 2002 02:54 PM
rickC1
Apr 1, 2002 09:13 AM
