what pistons to use? (B18c1 block & B17 head)
Im guessing this is a poormans' ITR, and I've read about a lot builds, but what pistons would work the best for daily street driving?
OS JDM B16 pistons
OS JDM ITR pistons
OS JDM CTR pistons
I think the CTR pistons will push the CR a little too high, So I'm leaning towards either the ITR or b16.
The B16 give a little higher CR than the ITR, but will it be that much of a differnce between the ITR and the B16 pistons?
The head will stay stock for a few months till I can afford to build that too.
OS JDM B16 pistons
OS JDM ITR pistons
OS JDM CTR pistons
what block and head r u using? ans also has the head been milled any whatsoever , or has the block deck been surface any at all and what head gasket r u using , if u give me all that info i can calculate it for u
B18c1 Block - No mill or resurfacing
B17 Head - No mill
Stock Headgasket
I've checked c-speedracing.
I just want to know what piston would be better for everyday street driving on 93 octane gas.
If the CTR Pistons will be ok for street driving on 93 octane, than I will use those, but I dont want to have my compression so high that it would be causing problems.
I need a good daily driving motor. Don't want the CR too high.
Just want to know what pistons have worked the best for a daily driver setup.
B17 Head - No mill
Stock Headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan Ruddock »</TD></TR><TR><TD CLASS="quote">I would get some P30 b16 pistons. Do not use ctr cr tooooo high. Dan</TD></TR></TABLE>
that is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr »</TD></TR><TR><TD CLASS="quote">
During the debate about compression ratio it was found that this site
http://www.zealautowerks.com/index.html
had better accuracy.
that is correct.
hott95ej2
Sep 25, 2005 10:35 AM
Nikos
Jul 2, 2003 08:59 AM
