does n e one have a write up on putting a 1st gen b16 in aa 1991 crx si
Old Mar 26, 2006 | 09:14 PM
beatthisspeed69's Avatar
Default does n e one have a write up on putting a 1st gen b16 in aa 1991 crx si
basically wat the title says made a thread b4 but didnt realy get the answers i was looking for. but mainly i just want to no wat wiring i will need to do.and wat will i have to get like axles shift linkage etc. and im pretty sure i do not need after market motor mounts for a 1st gen b16.n e help is welcome.thnx ahead of time
Old Mar 26, 2006 | 10:06 PM
jacoop86's Avatar
Default Re: does n e one have a write up on putting a 1st gen b16 in aa 1991 crx si (beatthisspeed69)
there is a hell of a lot of write ups if you search... try google. but to answer your questions:
the only wiring you need is the VTEC Solenoid, VTEC Oil Pressure Switch, 2nd Oxygen Sensor and Knock Sensor
axles:
the passenger side uses 90-93 integra,but the drivers side depends on what half-shaft you are using. 1st gen b16a's used 2 different shafts:
the sh3 shaft uses a custom drivers side or JDM SiR axle (usually y1 tranny)
the sk7 shaft uses a 90-93 integra drivers side axle (usually s1/j1 tranny)
shift linkage is custom from hasport, arizona race, or a few others. or you could cut and weld one from a da integra
ohhh and you DO need custom mounts, unless you want to try your luck on welding your own custom mounts and hoping they line up right.
here are some links i've found on the swap:
http://www.norcalcrx.org/dropp...p.htm
http://www.geocities.com/teampimports/b16a.html
http://www.customcivics.com/ar...2f509&
http://www.phatwhippincrx.20m.com/custom.html
http://www.geocities.com/Motor....html
http://www.norcalcrx.org/droppedcrxsi/B16a.htm
Da1spaz247
Jul 12, 2006 01:26 PM
Combustion Contraption
Sep 8, 2004 05:51 PM
Downey
Jun 15, 2004 07:12 AM
wpgcivic
Dec 26, 2003 06:53 AM
