Question: JDM ITR 5 lugs conversion on DC2
Old Mar 26, 2006 | 07:36 PM
PaChiLa Leader's Avatar
Default Question: JDM ITR 5 lugs conversion on DC2
im planning on getting a jdm 5lug conversion and i found out that they need 36mm axles from jdm itr. i was reading up on if there is a way to get around buying jdm axles and some people said that i can just get the cv joint from a prelude or accord and put it on a b series axles and it would work. i was wondering if anybody has done it before? and is it the easy as repairing cv boot?
Old Mar 28, 2006 | 03:12 PM
99_dc2's Avatar
Default Re: Question: JDM ITR 5 lugs conversion on DC2 (PaChiLa Leader)
I've heard that you can do it with the 97-01 preludes outer cv joints or the honda crv. I've never done it before but I was about to until I decided to get some jdm axles to avoid running into other problems. Now I have an extra set laying around just incase my other axles run out..
Old Mar 28, 2006 | 03:38 PM
OUT OF ORDER ROB's Avatar
i say get 32mm usdm So you dont have to waste your time making axles.
Default Re: Question: JDM ITR 5 lugs conversion on DC2 (99_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that you can do it with the 97-01 preludes outer cv joints or the honda crv. I've never done it before but I was about to until I decided to get some jdm axles to avoid running into other problems. Now I have an extra set laying around just incase my other axles run out..</TD></TR></TABLE>
icic... hey man.. one question.. for JDM axle do i need both sides?? driver and passenger
Old Mar 28, 2006 | 03:51 PM
Default Re: (OUT OF ORDER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT OF ORDER &raquo;</TD></TR><TR><TD CLASS="quote">i say get 32mm usdm So you dont have to waste your time making axles.</TD></TR></TABLE>
believe me i would if i can~
Old Mar 28, 2006 | 04:33 PM
WhoDoYouThink's Avatar
Default Re: (PaChiLa Leader)
so why not get USDM 5 lug and save some hassle?
nm: didnt see it already posted. sry
Old Mar 28, 2006 | 04:47 PM
SlammedDC2teg's Avatar
Default Re: (2000turbogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaChiLa Leader &raquo;</TD></TR><TR><TD CLASS="quote">im planning on getting a jdm 5lug conversion and i found out that they need 36mm axles from jdm itr. i was reading up on if there is a way to get around buying jdm axles and some people said that i can just get the cv joint from a prelude or accord and put it on a b series axles and it would work. i was wondering if anybody has done it before? and is it the easy as repairing cv boot?
Yes you can do that, Also raxels.com makes axles for that set-up and they go for around 400bucks. Why go with the US 5lug if it has weaker axles. I have been rolling a JDM 5lug for over a year and have had no problems. If you think about it you shouldnt be worried about axles, they are ment to last. The only reason people are telling u to go with a US set-up is because they think that finding jdm axles is hard. Trust me its as easy as getting US ones if you know what you are doing. Also the guy at raxels.com is really cool and has the axels already made.
Old Mar 28, 2006 | 04:51 PM
Default Re: (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you can do that, Also raxels.com makes axles for that set-up and they go for around 400bucks. Why go with the US 5lug if it has weaker axles. I have been rolling a JDM 5lug for over a year and have had no problems. If you think about it you shouldnt be worried about axles, they are ment to last. The only reason people are telling u to go with a US set-up is because they think that finding jdm axles is hard. Trust me its as easy as getting US ones if you know what you are doing. Also the guy at raxels.com is really cool and has the axels already made.</TD></TR></TABLE>
thanks for the great info
i will double check with them
but the way, do i have to change the intermeidate shaft? i dont' think so right?
i will only need the 36mm axle for driver/passenger sides in order to use the JDM ITR 5 lugs right?
Old Mar 28, 2006 | 09:10 PM
The half shaft is fine. You will only need the axles. Here is the exact web page incase the other one didnt work. http://www.raxles.com/. I wouldnt worry about changing axles, they take awhile to get messed up. You can also go with the civic type r 5 lug, its the same as the US coversion 32mm.
2tonedc2
May 22, 2008 03:42 PM
frankenstein ek9
Apr 5, 2008 10:52 AM
99_dc2
Suspension & Brakes
Oct 1, 2005 09:58 PM
boosted dc
Jan 26, 2004 02:33 PM
neof69
Oct 10, 2002 06:50 PM
