Replace valve cover gasket?
Old Mar 26, 2006 | 07:31 PM
g3teg97's Avatar
Default Replace valve cover gasket?
I'm thinking about repainting my valve cover because the paint is peeling off. Would I need to replace the valve cover gasket if I take the valve cover off just to paint it?
Old Mar 26, 2006 | 07:36 PM
Racermech's Avatar
Default Re: Replace valve cover gasket? (g3teg97)
better safe than sorry, the kit is not that expensive.
SlamminS85's Avatar
yeah you would have to if you want to maintain a good reliable seal... you could always try it, but you cant be sure, best just to replace it, while your at it do a valve adjustment
Old Mar 27, 2006 | 08:18 AM
g3teg97's Avatar
Default Re: Replace valve cover gasket? (SlamminS85)
Don't you have to replace the spark plug seals as well?
Old Mar 27, 2006 | 08:29 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g3teg97 &raquo;</TD></TR><TR><TD CLASS="quote">Don't you have to replace the spark plug seals as well?</TD></TR></TABLE>
those also come in the valve cover gasket set... You can either order the kit from honda or prostreetonline
Old Mar 27, 2006 | 10:27 AM
97tegGS's Avatar
OR any of your local parts stores. Felpro Rubber is fine. I beileve I paid 22 or 29 from advance auto. I cant remember the total
I just did mine this past weekend actually. I put 8 little dabs of rtv where the gasket will hump over the cams for added security.
tjlewis10
Jul 8, 2017 09:38 AM
Aodhan
Sep 28, 2007 10:15 AM
Midori Green
Jun 1, 2007 10:53 AM
civic91
Dec 31, 2003 07:44 AM
confucius
Mar 26, 2002 07:39 PM
