Rate my welds (MIG)
Old Mar 26, 2006 | 06:41 PM
passwordhatch's Avatar
Default Rate my welds (MIG)
Hey everyone im taking a structural welding class in school and wanted to know your input on my welds ive been practicing. im using a Lincoln mig welder, not sure of the model.
these are both overhead
butt with backing plate and plug
comments welcome on how to improve
Old Mar 26, 2006 | 07:37 PM
TurBros's Avatar
Looks ok, why dont you lay a longer bead and then try to get some input. Would make more since.
Old Mar 26, 2006 | 07:48 PM
JunY's Avatar
Default Re: (TurBros)
Because he's doing I-CAR weld test plates. Pretty good. I'm asuming your using Lincoln SP-135 Plus at school. Now check with the level gauge that was handed to you for the length, width, height, and diameter; and do the destructive test to see if it's aplicable.
PS: You cant use GMAW for structural. Only SMAW or Flux-core for Structural welding.
Old Mar 26, 2006 | 08:57 PM
sc4dr's Avatar
Default Re: (JunY)
I passed that crappy test. Now go weld some paper thin import sheet metal together using the same techniques, and see what happens. Welds look decent, you got a little impatient at the end of your butt with backing, probably good enough to pass though
Old Mar 26, 2006 | 09:07 PM
Default Re: (sc4dr)
yeah i passed the I-CAR test also, these were taken at the begining on the semester, sept of 05
Old Mar 27, 2006 | 05:34 AM
dfoxengr's Avatar
Default Re: (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">I passed that crappy test. Now go weld some paper thin import sheet metal together using the same techniques, and see what happens. Welds look decent, you got a little impatient at the end of your butt with backing, probably good enough to pass though </TD></TR></TABLE>
how did he get impatient?
Old Mar 27, 2006 | 05:41 PM
blueoval557's Avatar
Default Re: (dfoxengr)
The last of the weld isnt as wide as the rest of the bead, meaning he didnt sit there and fill in the last second or two, but stopped a little early. They look great and would pass for anything most likely. Only suggestion I could give you would be turn the wire speed down just a LITTLE BIT...could be the pictures too, but it looks like they may be SLIGHTLY too much filler wire in there. Lookin great though!
Kyle
Old Mar 27, 2006 | 05:52 PM
dfoxengr's Avatar
Default Re: (blueoval557)
that is the beginning of the weld i believe.
the end is the top in the first pic posted. the puddle follows you...
-derek
Old Mar 31, 2006 | 03:00 PM
Mr.Wrench's Avatar
Default Re: Rate my welds (passwordhatch)
Looks good just keep practicing
Old Apr 2, 2006 | 06:25 PM
supercreed2002's Avatar
Default Re: Rate my welds (Mr.Wrench)
shitty welds....j/k, ease up on the filler.
Old Apr 2, 2006 | 06:37 PM
HamiltonRex's Avatar
Default Re: Rate my welds (supercreed2002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercreed2002 &raquo;</TD></TR><TR><TD CLASS="quote">shitty welds....j/k, ease up on the filler.</TD></TR></TABLE>
Its a mig... You dont add filler will mig.
He could slow his wire speed BTW your welds are very good for overhead!
Old Apr 2, 2006 | 07:41 PM
rkeith's Avatar
Default Re: Rate my welds (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
He could slow his wire speed BTW your welds are very good for overhead!</TD></TR></TABLE>
Actually you do, just not manually.
Old Apr 7, 2006 | 07:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Its a mig... You dont add filler will mig.
::scratches head:: huh?
Old Apr 7, 2006 | 08:37 PM
kawgomoo's Avatar
motorsports welding and structural are diff ****. for race car looking welds try a C motion with a little whip hesitation. or do the dot-dot-dot thing. which is just welding spots on at a t ime. this gives you the stacked dime appearence, and lets things cool between dots so you dont blow through thin metal.
jj07
Welding / Fabrication
27
Jan 26, 2010 02:05 PM
JunY
May 20, 2005 10:27 PM
ghettoracer
25
Nov 26, 2002 11:47 AM
io_burn
Nov 12, 2002 07:20 AM
