s4c transmission problem, check it out please
Old Mar 26, 2006 | 06:21 PM
Mr. Em1's Avatar
Default s4c transmission problem, check it out please
After my first transmission blew due to a hole getting knocked into, and spending 950 on a new transmission, i have yet another problem. I have a 99 si and i replaced the tranny with another s4c that has about 25k on it. One day im driving and some lady pushed me off the road, a look under my engine bay when i get home from school, and the top of the transmission mount in the front is shot. The whole top two bolts are gone. I went to go to the spot where i was pushed off the road and nothing is to be found. i was wondering what would be the best fix for this in my situation because i want this to get fixed before i do my swap. thanks for your help guys i really appreciate it.
Modified by Ninefivejiggaja at 8:00 PM 3/27/2006
Old Mar 26, 2006 | 06:46 PM
hatchi's Avatar
Default Re: s4c transmission problem, check it out please (Ninefivejiggaja)
you would probably have to bring it to a shop to get rethreaded
Old Mar 26, 2006 | 06:49 PM
Mr. Em1's Avatar
thats what i planned on doing but i was wondering how much people were paying to get it done.
Old Mar 27, 2006 | 09:25 AM
Mr. Em1's Avatar
has anybody else experienced this problem at all?
Old Mar 27, 2006 | 04:01 PM
Mr. Em1's Avatar
sorry for the big pic but i think its better to see it bigger because its small
Old Mar 27, 2006 | 04:04 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninefivejiggaja &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering what would be the best fix for this in my situation because i want this to get fixed before i do my swap. [/url]</TD></TR></TABLE>
I'm assuming you aren't getting a new tranny with your "swap."
Unfortunately, IMHO that transmission is toast. You could try and find a new case, and have the mainshaft and countershaft re-shimmed to work, but I wouldn't even bother. Structurally, that's a vital part of the tranny. I wouldn't feel safe having it welded over and then re-tapped.
Old Mar 27, 2006 | 04:29 PM
Mr. Em1's Avatar
i hate this shti, this transmission has 25k on it and now its toast because of a little ****** piece broke, that sucks, man i just dont know what to do
Old Mar 27, 2006 | 04:33 PM
Risky Business
Default Re: (Ninefivejiggaja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninefivejiggaja &raquo;</TD></TR><TR><TD CLASS="quote">i hate this shti, this transmission has 25k on it and now its toast because of a little ****** piece broke, that sucks, man i just dont know what to do</TD></TR></TABLE>
Um, you said you were forced off the road. Be glad its only the transmission that's fucked. Like I said you can try finding another case but you're going to have to have the shafts re-shimmed.
Old Mar 27, 2006 | 05:00 PM
Mr. Em1's Avatar
no i understand im just very frustrated and i appreciate your help.
Old Mar 27, 2006 | 05:23 PM
adictionbass's Avatar
get a new case and when you do your swap, switch the cover and reshim it
Old Mar 27, 2006 | 05:53 PM
Mr. Em1's Avatar
im not exactly asure by what you mean by reshimming it.
Old Mar 27, 2006 | 05:55 PM
rbanke's Avatar
Default Re: (adictionbass)
You can simply get the new housing (you only need the outer half) and replace it, measure the diff for the shim youll need and get that too, and your done. You can find ppl selling tranny cases pretty often, it would be silly to toss this tranny simply because of a external problem.
EDIT: im not so sure how you feel about doing work by yourself, if you did want to to it, buy the Helm manual. If you dont feel comfortable, im sure you can bring your parts to a shop in your area and have them to it, its really not a hard job (ive done it 2 times this week)
Modified by rbanke at 10:14 PM 3/27/2006
Old Mar 27, 2006 | 06:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninefivejiggaja &raquo;</TD></TR><TR><TD CLASS="quote">im not exactly asure by what you mean by reshimming it.</TD></TR></TABLE>
you have to shim the differential so it has a certain amount of movement.
Old Mar 27, 2006 | 06:44 PM
Mr. Em1's Avatar
alright im going to look for a new case, i really appreciate your guys help.
Old Mar 27, 2006 | 06:46 PM
NJcoupe's Avatar
PM lilman213.
He has a b16 trans casing.
Old Mar 28, 2006 | 03:28 AM
Mr. Em1's Avatar
thanks for your help ill message him now
Old Nov 11, 2006 | 04:55 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: (Mr. Em1)
if your trans doesnt leak then just replace the top mount with a hasport
Old Nov 11, 2006 | 06:11 PM
axtran's Avatar
Default Re: (H22EHSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EHSI &raquo;</TD></TR><TR><TD CLASS="quote">if your trans doesnt leak then just replace the top mount with a hasport</TD></TR></TABLE>
what?
don't listen to that guy...
just get a new transmission, but $950 is way too steep to be paying for one.
Old Nov 11, 2006 | 06:39 PM
Default Re: (axtran)
what? how many people run that mount anyway....im runnin a h2b with stock mounts and just insterts on the rear and it doesnt move at all
NC-SI
May 4, 2013 11:08 AM
Thunder Cat
Feb 24, 2007 07:49 AM
Shake and Bake
Jun 30, 2006 07:14 PM
lePetitePrince
May 29, 2002 10:30 PM
vtecguy
Jan 6, 2002 08:30 PM
