S2k cluster in 88 si?
Old Mar 26, 2006 | 02:40 PM
Dice21's Avatar
Default S2k cluster in 88si
i just dont understand how to make the speedo work in my si? What good is the cluster if it dosnt work like stock or better.
Modified by Dice21 at 6:57 PM 3/26/2006
Old Mar 26, 2006 | 02:43 PM
ruffie_PL's Avatar
Default Re: S2k cluster in 88 si? (Dice21)
The post was successfully reported to the moderator....
https://honda-tech.com/zerothread?id=1213471
I hate stupid n000bs
Old Mar 26, 2006 | 03:06 PM
payneth's Avatar
Default Re: S2k cluster in 88 si? (ruffie_PL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffie_PL &raquo;</TD></TR><TR><TD CLASS="quote">The post was successfully reported to the moderator....
I hate stupid n000bs </TD></TR></TABLE>
lol
Old Mar 26, 2006 | 03:13 PM
Dice21's Avatar
that dam link dosnt tell me how to make the speedo work in my si!!!
Old Mar 26, 2006 | 03:16 PM
ruffie_PL's Avatar
Default Re: (Dice21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dice21 &raquo;</TD></TR><TR><TD CLASS="quote">that dam link dosnt tell me how to make the speedo work in my si!!!</TD></TR></TABLE>
dam - how st0000pid u r? Cant read a think sometime or what? Is Civic so much different from CRX?
Old Mar 26, 2006 | 03:19 PM
Dice21's Avatar
yes it is u monkey
Old Mar 26, 2006 | 03:23 PM
ruffie_PL's Avatar
I dont think so smartass...
Old Mar 26, 2006 | 03:34 PM
Dice21's Avatar
well considering i have a 88si and all pre 92' arent outfitted with a vss so i dont understand.
Old Mar 26, 2006 | 03:36 PM
ruffie_PL's Avatar
Best solution? Install VSS or something which will generate same signal as VSS.
Old Mar 26, 2006 | 03:37 PM
Dice21's Avatar
....no **** surlock....i dont know where to find one let alone how to wire it up to an s2k cluster.
Old Mar 26, 2006 | 03:52 PM
ruffie_PL's Avatar
Ehh - this thing is called "reading with understanding" or smth like that...
Old Mar 26, 2006 | 03:55 PM
STREETWERKZ's Avatar
Default Re: (ruffie_PL)
i like the eyeball avatar.
can i have it?
Old Mar 26, 2006 | 04:26 PM
Dice21's Avatar
nah then i wouldnt be unique
Old Mar 26, 2006 | 05:43 PM
bigcalidave's Avatar
First step is to put an electric VSS from a 92+ civic into your crx. Civics and CRXs are pretty much the same thing, btw. Then look into this thread for all the info I have posted on doing the cluster swap, look at the last few pages.
https://honda-tech.com/zerothread?id=762288
Old Oct 20, 2006 | 12:24 PM
harmonator84's Avatar
Default Re: (bigcalidave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcalidave &raquo;</TD></TR><TR><TD CLASS="quote">First step is to put an electric VSS from a 92+ civic into your crx. Civics and CRXs are pretty much the same thing, btw. Then look into this thread for all the info I have posted on doing the cluster swap, look at the last few pages.
https://honda-tech.com/zerothread?id=762288</TD></TR></TABLE>
See instead of fighting you can help each other out. We are all honda fans here guys.
Old Oct 20, 2006 | 02:00 PM
doublethink's Avatar
Default Re: (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">See instead of fighting you can help each other out. We are all honda fans here guys. </TD></TR></TABLE>
we're all honda fans, and here at honda-tech were fans of SEARCHING and not being a ******** child demanding information.
people who do that should be f*cked with.
you need a 92+ d-series VSS, you install it, and run athe signal wire to the cluster, but then you are NOT FINISHED.
THEN you need a converter to convert the civic vss pulses into something the sk2 cluster can display properly.
they sell these units on ebay, and im repeating info thats all easily found on here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dice21 &raquo;</TD></TR><TR><TD CLASS="quote">i just dont understand how to make the speedo work in my si? What good is the cluster if it dosnt work like stock or better.</TD></TR></TABLE>
your performing a visual mod, and you didnt do your homework. on a real basic level, its not any better then a stock si cluster. they both perform the same functions, the s2000 cluster is all digital and very nice looking.
that is why you do somehting like this, but since the temp and vss are different in how the obd2 electronics and the ecu are involved in the s2000 that you got the cluster from, you cant just hook it up wire to wire and have all the features work properly.
Old Oct 20, 2006 | 02:20 PM
Default Re: (doublethink)
if you want, you can also send the cluster out to have it modified to accept stock honda sensors, (vss and temp guage) theres a man named mark who performs these conversions, his web site is here:
http://www.marklamond.co.uk/pr...0.htm
JDean6pac
Sep 4, 2007 09:34 PM
Ej896
Jul 17, 2007 07:58 AM
ek9vboi2
Jul 16, 2007 06:05 AM
bmoua
Jun 13, 2007 03:22 PM
Dc2 Powered
Sep 24, 2004 04:05 PM
