B18c in a 91 CRX will the hood still close?
Old Mar 26, 2006 | 01:15 PM
mrtrex's Avatar
Default B18c in a 91 CRX will the hood still close?
If I do the swap will I have enough clearence to close the hood? If not what do I ned to do to make it close?
Old Mar 26, 2006 | 01:32 PM
90JDMEF8's Avatar
Default Re: B18c in a 91 CRX will the hood still close? (mrtrex)
Ive seen people take a DOHC ZC Hood and cut the supports and it fit. Or even a stock hood and cut the supports. But you can also take your hood and vent it like an inch and it will give you the clearence you need plus it allows better air flow through your engine bay for a cooler running engine. If it is vented then it will run at about 1/4 on your temp guage, thats about half of what it will run with the hood stock. All you need to vent it is longer 10mm bolts and 1 in spacers to fit between the hood brackets and the hood...
Old Mar 26, 2006 | 01:46 PM
ruffie_PL's Avatar
If u have B16 engine hood will close. But i u have D series SOHC probably u will need hood from DOHC car (doesnt matters will it be from B or D series).
Old Mar 26, 2006 | 06:28 PM
K DOHC_19's Avatar
Default Re: B18c in a 91 CRX will the hood still close? (ruffie_PL)
My brother has a 91 hatch with a b16 in it and it fits fine.
Old Mar 26, 2006 | 06:40 PM
JohnnieChimpo's Avatar
I have seen a CRX w/GSR on Hasport mounts. The hood shuts but it did develop a few dents from the inside where the valve cover is rocking up and banging the hood. One plan is to add 1/4 spacers on the driver and passenger mounts. The valve cover also has some wear mounts where it has been rubbing forward and back against the hood.
Modified by JohnnieChimpo at 2:55 PM 4/11/2006
Old Mar 26, 2006 | 08:39 PM
spcrxracer's Avatar
Default Re: B18c in a 91 CRX will the hood still close? (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">I have a CRX w/GSR on Hasport mounts. The hood shuts but I did develop a few dents from the inside where the valve cover is rocking up and banging the hood. </TD></TR></TABLE>
Same thing with me but no dents in the hood. What happend with me is the hood started rubbing the valve cover and now i have some nice "Fang Looking" marks on it. My hood was even washered up at the hinges (the hood hinges by the windshield) and this still happend. I just ended up cutting a few pieces of the underskeleton on the OEM hood til my JDM styled carbon fiber hood arrived. (made to fit usa front end crx's)
Modified by spcrxracer at 9:25 AM 3/28/2006
Old Mar 27, 2006 | 08:58 AM
mrtrex's Avatar
Default Re: B18c in a 91 CRX will the hood still close? (spcrxracer)
Where did you get the JDM style hood made to fit the usdm car? Sounds like this is a good option for me.
Old Mar 27, 2006 | 09:50 AM
beyondspexj's Avatar
vis and siebon have them. its the SiR style hood for the usdm front end. basicly the middle of the hood comes up ( instead of down like our oem hoods do ) thus clearing the valve cover
Old Mar 27, 2006 | 10:23 AM
Mugencrxsir1's Avatar
Default Re: (beyondspexj)
Yes your stock hood will close with gsr motor! No need to get a CF hood, unless you want too.
Old Mar 27, 2006 | 10:42 AM
b.d.racing's Avatar
Default Re: (Mugencrxsir1)
Please elaborate on how you got your stock hood to shut with a B18C. Did you cut your inside of the hood up, did you use washers where the hood mounts, and what mounts did you use?
Old Mar 27, 2006 | 11:47 AM
HT Chaplain's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">Yes your stock hood will close with gsr motor! No need to get a CF hood, unless you want too.</TD></TR></TABLE>
x2
just cut a little bit of webbing on the hood
Old Mar 27, 2006 | 03:02 PM
b.d.racing's Avatar
Default Re: (HT Chaplin)
Yeah but what mounts are you guys using? I'm hearing the EFB1 mounts won't work even if you cut the hood. I have the EFB1 mounts so I'm curious if I can use a stock hood.
Old Mar 27, 2006 | 03:59 PM
Arvid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote">
Same thing with me but no dents in the hood. What happend with me is the hood starting rubbing the valve cover and now i have some nice "Fang Looking" marks on it. My hood was even washered up at the hinges (the hood hinges by the windshield) and this still happend. I just ended up cutting a few pieces of the underskeleton on the OEM hood til my JDM styled carbon fiber hood arrived. (made to fit usa front end crx's)</TD></TR></TABLE>
I have the exact same marks on my valve cover. I´m using a CF ZC hood with cut out underskeleton , I even grinded away as much as I dared of the CF hood itself to get more clearance. I´m using Hasport mounts.
BTW , what kind of radiator are you using ? Is it a DA radiator (if so , how is does it fit) ?
Old Mar 27, 2006 | 04:00 PM
paopao's Avatar
Default Re: (b.d.racing)
Yeah, this all really depends on the motor mounts you use. I hear the new Hasport mounts place the motor really well. I have the same problem that spcrxracer had:
Old Mar 27, 2006 | 05:09 PM
mrtrex's Avatar
Default Re: (paopao)
So what are the best mounts to use??
Old Mar 27, 2006 | 06:13 PM
paopao's Avatar
Default Re: (mrtrex)
Well, I heard the Hasports were supposed to be the shiznit, but apparantly some guys are still getting clearance issues with them. I myself am using some old school mounts that I don't even know the name of.
Old Mar 27, 2006 | 06:20 PM
Down Shift Motoring's Avatar
anyone need the hasport efb2 mounts with hydro actuator??? will sell for 370 shipped brand new!
Old Mar 27, 2006 | 06:46 PM
flatblack crx's Avatar
gsr swap in mine i have no problems
Old Mar 28, 2006 | 06:31 AM
spcrxracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspexj &raquo;</TD></TR><TR><TD CLASS="quote">vis and siebon have them. its the SiR style hood for the usdm front end. basicly the middle of the hood comes up ( instead of down like our oem hoods do ) thus clearing the valve cover</TD></TR></TABLE>
yep! Cuz the hood "puffs" up in the middle.
The only difference between JDM and USDM is the way the hood latches . The latches are different, so it's the same design, just built for the USDM latch.
And yes, the stock hood WILL close, also. But the back part of the valve cover will still rub the webbing. You'll end up basically having to cut out the entire middle portion of the OEM D-series CRX hood (thus leaving the thin sheet metal without support). I just thought the CF Hood looked cleaner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arvid &raquo;</TD></TR><TR><TD CLASS="quote">BTW , what kind of radiator are you using ? Is it a DA radiator (if so , how is does it fit) ?</TD></TR></TABLE>
My radiator is a C&R radiator w/SPAL lightweight, super fast fan. It's made for the CRX. Fluidyne and Koyo are also GREAT products. A bit more blingy (shiny) than C&R. I just liked C&R cuz it came with the SPAL fan and it was good value.
Old Mar 28, 2006 | 08:33 AM
Chase's Avatar
Default Re: (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">
It's been Converted to OBD-1 p28 ECU and a JDM 95 Y80 L.S.D Hydro Tranny </TD></TR></TABLE>
dude howd u do the clutch MC setup in there???? Any more info?
Old Mar 28, 2006 | 05:38 PM
Default Re: (spcrxracer)
Not flaming but you do know the headlights are differnt too? The "USDM SiR" hood is made for the small USDM headlights and latch and it "puffs up"
Putting a JDM hood on a USDM car will look like *** if you don't add the JDM headlights and bumper. That's why they make a USDM SiR hood.
Old Mar 28, 2006 | 06:03 PM
spcrxracer's Avatar
Default Re: (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Not flaming but you do know the headlights are differnt too? The "USDM SiR" hood is made for the small USDM headlights and latch and it "puffs up"
Putting a JDM hood on a USDM car will look like *** if you don't add the JDM headlights and bumper. That's why they make a USDM SiR hood.</TD></TR></TABLE>
Yeah! Thanks Bro, i forgot that. I was in a hurry typing cuz i was in class!
Old Mar 28, 2006 | 10:58 PM
b.d.racing's Avatar
So the answer is it will work but am I going to be saying goodbye to my freshly redone valve cover shine?
Old Apr 10, 2006 | 10:38 AM
memicah's Avatar
I'm curious about this as well. Does anyone have a b18c motor in their crx with the efb2 mounts... whats my best hood option haha. Further up someone said that the new efb2 mounts set the motor well and there aren't any issues? Can anyone confirm this? Thanks so much!
Old Apr 10, 2006 | 12:19 PM
CRX Toad's Avatar
Just cut some pieces of the hood support out and your will be good to go.
B16Drag
Apr 25, 2010 07:14 AM
sw96
16
Aug 24, 2009 10:00 AM
tylojake
Dec 23, 2008 11:46 PM
gooknom
Feb 17, 2004 09:13 AM
93slmdcvcsi
Jan 7, 2004 06:35 PM
