How close to a 1.0G cornering force will I be able to obtain with my new setup?
Old Apr 3, 2002 | 08:08 AM
SlyGSR's Avatar
Default How close to a 1.0G cornering force will I be able to obtain with my new setup?
From my stock GSR to...
Toyo T1-S
H&R OE
KYB AGX
22mm Rear Sway Bar
Cross-Drilled Rotors
Metal pads
etc..
I believe a stock integra is about 0.87?
Oups..I added the tires..forgot
TIA
SlyGSR
[Modified by SlyGSR, 5:17 PM 4/3/2002]
Old Apr 3, 2002 | 08:13 AM
bps2799's Avatar
Default Re: How close to a 1.0G cornering force will I be able to obtain with my new setup? (SlyGSR)
Tires???
Should've bought Brembo blanks instead of x-drilled, but don't worry, you'll probably be buying some new rotors again soon anyhow, after they crack from the drilled-in holes.
Old Apr 3, 2002 | 08:46 AM
2005 TSX's Avatar
Metal pads
Maybe I am wrong, but rotors and brake pads aren't going to help in giving you a 1g turning/cornering force. But then again, I am still a newbie at all of this stuff.
Old Apr 3, 2002 | 08:57 AM
SlyGSR's Avatar
Default Re: How close to a 1.0G cornering force will I be able to obtain with my new setup? (2001 Integra GS
your right...just listing the complete setup
Old Apr 3, 2002 | 10:40 AM
drifter's Avatar
personally i don't think you'll hit 1g but still a good set up
Old Apr 3, 2002 | 11:30 AM
HondaJon's Avatar
You probably will not be at 1.0 lateral g's, but you should be fairly close with that setup. The H&R OE springs may be just a little too soft to take on 1.0 lateral g's.
That's just from what I have seen some setups do, let us know how you do, you could very well prove me wrong.
Jon
Old Apr 3, 2002 | 12:08 PM
Mario's Avatar
You might want to swap out those T1-S for the RA-1...a HUGE improvement.
I also agree that the H&R OE sports are too soft (I had these).
Old Apr 3, 2002 | 01:05 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
You'll most likely need a set of R-Compound tires...
Go find the OLD SCHOOL turbo mag w/ the del sol... progress sus, swaybar(s), and some r compounds... 1.0 or so...
or that SCC project si hit 1.0+ on hoosiers..but those aren't really street tires..
Who cares about skidpad anyway? Motor Trend?
GSRCRXsi
37
Aug 8, 2010 11:48 PM
MDM
21
Aug 20, 2007 09:54 PM
bossman032
Jul 4, 2006 01:45 AM
RTW DC2R
Aug 15, 2003 07:28 PM
teamlegacy
Jul 19, 2003 01:51 AM
