gsr clutch: axle nut
Old Mar 26, 2006 | 12:13 PM
teddy_dc2's Avatar
Default gsr clutch: axle nut
got the driver side axle nut out, passenger nut won't turn and starting to strip, any suggestions how to get off??
Old Mar 26, 2006 | 12:37 PM
teddy_dc2's Avatar
i tried heating it up with a torch, any suggestions? tips?
Old Mar 26, 2006 | 01:03 PM
teddy_dc2's Avatar
anyone?
Old Mar 26, 2006 | 01:28 PM
Shaun's Avatar
you need leverage or some type of impact gun.. ghetto but works use some type of pipe put it at the end of the breaker bar and loosen it, spray it with wd 40 also
Old Mar 26, 2006 | 01:33 PM
teddy_dc2's Avatar
i tried that but it's still tight, the bar is pretty much bent, no impact gun at the moment. im gonna heat it up for a few (5-8mins) and see what happens, the nut is strippin.
Old Mar 26, 2006 | 03:11 PM
skata89's Avatar
i did mine the ota day. gets a 3/4 breakbar and a 6 foot pool and stand on it.
Old Mar 26, 2006 | 03:56 PM
JThrasher79's Avatar
Default Re: (skata89)
yeh i have broke 2 snap-on 3/4 breaker bars on the same spinde nut consecutively. i just put a long steel pole over the breaker bar and turn it, either the breaker bar will break or you will get the nut off. good luck..
Old Mar 26, 2006 | 04:04 PM
teddy_dc2's Avatar
got it, wheel keeps spinnin so we lower with tires on ground, went with next size smaller and jumped on the bar, the nut twisted out. thanks for the help
Old Mar 26, 2006 | 04:48 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (teddy_dc2)
What type of socket are you using? Don't use a 12 point, it will strip if it's really tight on there. Use a 6 point.
EDIT: Alrighty, didn't see your last post there. Good job.
Old Mar 26, 2006 | 06:08 PM
teddy_dc2's Avatar
shift linkage wont come outout, how many quart of (5w30 oil?) goes back into the tranny?
Old Mar 26, 2006 | 06:17 PM
Tornadom's Avatar
I used Honda MTF in my trans-axle. I think it takes just under three (3) quarts. Fill it up until it just starts to run out of the fill hole. If you choose to fill through the speed sensor hole, just remove the fill plug and watch for the fluid to get up to it.
Old Mar 26, 2006 | 06:28 PM
Default Re: (Tornadom)
do NOT use motor oil in your trans, i use mobile1 tranny fluid
Dj Porboi
45
Aug 4, 2010 04:39 PM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
Quetzolcotl
May 9, 2006 06:04 PM
2k1_ITR_0736
14
Jan 13, 2003 10:48 PM
20lb.teg
Oct 8, 2002 09:13 PM
